New Windows Software Version
Started by AirNav Development, November 13, 2014, 11:55:49 PM
Ok Alan, in that case I'll do some investigation until next weekend. Or maybe I just should ask Andre (Aleksey), what that number is really meaning.
Do you mean the figure in bold at the left top of the grid.  If so I thought it was the number of aircraft picked up in the time span.
No, I don't mean that figure, which is showing the number of aircraft picked up in the selected time span with the exception of all aiframes, that have been picked up later as the selected time span.
That means each airframe that has picked up during the selected time span is remuved from the list, as soon as it is received later as the upper time end of the selected time span. Therefore only airframes with a last receiption time within the selected timespan are shown in the list. If you don't change the timespan, the number of received airframes within the timespan decreases continiously.
Im mean the number that is shown after you go to MyLog -> Tools -> Ppopulate -> confirming 1st message: This function can take some minutes. followed by this message
460 Aircraft(s) Updated. Once all pending photos / aircraft information is downloaded the MyLog Screen is automatically refreshed.
I think, that this figure shows the number of airframes without details in the selected time span. Anyway, the second part of the message is incorrect, as it always needs a second (third) run of populate to get the airframes entries im MyLog updated. It never had worked automatically. Well, unless the particular airframe was received again. In that case MyLog was updated.
Oh, I  have never had more than 3 or 4 when I run populate and it completes in seconds but then I update every day so don't experience what you are experiencing.
Hi Alan, do you by any chance know, how many airframes you have added/amended in the server database since November 19th?
The airframe count shown during populate cycle definitely doesn't show the number of airframes without details of a selected time span.
No idea Ingo I don't have time to count addition/amendments/deletions.  Worth remembering that some that were in have been deleted so its not as simple as only new ones to contend with.
I just wanted to let you know, that the problem "timed out flights remain on map and in the myflights  list" is still existing in the actual V5.00.072 Version. Deactivating - Reactivating the processing of flights received by own box using the ckeck-box "Process Hardware Flights"  in the bottom left corner of MyFlights list removes them.
#52
I will forward on this info, thanks Ingo.  I believe it may be something to do with the new server software but maybe not.
this problem is an old one that hadn't appeared for a while. I just wanted to inform about the fact, that it's still due to be fixed.
This time I had dbwin.exe running while it happened. Unfortunately file is 130MB, so I'll post it only if it's requested by airnav dev.
Not until I read the thread so I doubt Airnav will be aware but I will make them aware.
OK I will update the Task list
I have only access to App and RB24.com task list so I can't do the adding by myself.
Thanks!
