0 Members and 73 Guests are viewing this topic.
X
RA-76722  76MD  00734 75242  Russia - Air Force  Now RF-76722
RA-76731   76MD  00734 76290  Russia - Air Force
RA-76761   76MD  00734 79401   DBR Tver Russia 27/6/12
RA-76763   76MD  00734 80413  Russia - Air Force  Now RF-76763
RA-76766   76MDK 00834 81431 Now RF-75351 Roscosmos  Hex possibly now 152657 or 1?2657
RA-76767   76MD  00734 81436   Russia - Air Force
RA-76776   76MD  00834 82486   Russia - Air Force
RA-76792   76TD   00934 97942   WFU Zhukovsky Russia 09 ex Saturn NLO  D30KP engine test bed
X
jacobite
Good afternoon Alan, I need your help please. As there are a lot of new aircraft now appearing I have been adding them to the database manually, then when I go and check they are not there. I have been inputting the details required into the database but they all seem to disappear.
Ian (Jacobite)
Did you do the same as for the route info Ian other than that I have no idea what you are doing.  I would have thought that it would be a lot easier just to do a database download
jacobite
Quote from: Runway 31 on May 19, 2017, 11:56:06 AM
Yes Alan I did the same, maybe I should download the full D/B ignoring what I put in.
X
#10580
RA-76803     76MD  00934 97927  Now RF-76803 Ministry of Internal Affairs
RA-76806     76TD   10034 03121  B/U Moscow DME Russia 14 ex Airstars
RA-76807      76TD   10134 05176  Stored Bolbasovo Russia 13 ex Aviacon Zitotrans
RA-76817     76TD   10234 12387  WFU Fujairah UAE 10 ex United Nations (wears RA-76017)
RA-76829     76MD  10034 05172  Now RF-76829  Ministry of Internal Affairs  Stored Ermolino
RA-76843(2) 76TD  10134 08269   Stored Ryazan Russia 11 ex Airstars
RA-76849     76MD  00234 40161   B/U Bykovo Russia 13 ex Aviast
RA-78738   76TD       00334 42247   WFU Zhukovsky Russia 99 ex Gromov Air
RA-78776   76MD      00834 89652   Russia - Air Force
RA-78770   76MDK-2 00834 87617   Now RF-75352 Roscosmos  possibly now 152658 or 1?2658
RA-78798  78         00934 91747       Now RF-94282 Russia - Air Force    possibly 15704A or 1?704A
X
Unfortunately I cannot see what you are doing to offer any advice
I would suggest that you do the download Ian as the aircraft concerned will probably be in the database anyway.
Afternoon Terry, thanks again
Hello Alan,
no unknown airframes from me for some time due to many days of fight with the MyLog.db3. Finally I had to purge it completely, to start with an empty database.
Thursdays unknowns:
3D67DE  DFLOW no further information
MILs:
* 3E8210  GAF072                                                         2017/05/18 06:25:39
   3E88AE        2017/05/18 09:25:24
* 3E91B9        2017/05/18 13:56:44
   3EA986        2017/05/18 06:19:42
   3EAB9A        2017/05/18 09:51:29
   3F44B5        2017/05/18 10:23:55
* 3F7242        2017/05/18 10:29:07
* 3F9361        2017/05/18 10:25:46
* 3F9490  BURNER                                                         2017/05/18 08:03:42
* 3F9490        2017/05/18 13:07:03
* 3F9490  GUNNER                                                         2017/05/18 14:07:17
3FF5BC  DMYDA no further information
4C0672  YUBTS (2x) still no luck with the details
505C07  SSG04A SSG: Slovak Government Flying Service
That's it.
Just in case you didn't noticed it, Ian (EK01) asked you something at the WIN10 (1703) thread.
Regards Ingo
Just going out Ingo, will reply to you on return
X
RA-78805   76MD          00934 92783   Russia - Air Force
RA-78809   76MD          00934 93807   Russia - Air Force
RA-78823  78           10034 96918     Now RF-94288  Russia - Air Force
RA-78825    76MDK-2   10134  95871   Now RF-75353 Roscosmos
RA-78854   76MD90   10134 07220   Stored Ryazan Russia 14
RA-86741   76M            0834 12361    B/U Taganrog Russia 13
RA-86744   76M            0834 12376    B/U Taganrog Russia 13
RA-86842   76M          00034 23694    Russia - Air Force  flying in 2016
RA-86843   76M          00034 23701    Russia - Air Force  currently at ARZ123
RA-86849   76M          00034 26779    Russia - Air Force  flying in 2016
RA-86860   76M          00034 26759    B/U Tver Russia 12
RA-86871   76MD       00134 34002    WFU Zhukovsky Russia 03
RA-86872   76MD       00134 34008    WFU Tver Russia 10
RA-86874   76M         00134 29853    Russia - Air Force
RA-86875   76M         00134 29859    Russia - Air Force
RA-86882   76M         00134 31917    B/U Novgorod Russia 13
RA-86894   76M         00134 32977    DBR Ivanovo Russia 7/10/09
RA-86895   76M         00134 33985    B/U Staraya Rossi Russia 08
RA-86900   76MD       00234 35034    Stored Tver Russia 11
RA-86902   76MD       00234 36043    Russia - Air Force
RA-86907   76MD       00234 36065    Russia - Air Force
RA-86908   76MD       00234 37070    Russia - Air Force
X
X
RDPL-34155  76T      0734 11338   WFU Ras Al Khaimah UAE 10
RDPL-34163  76TD  00534 60832   Now UR-CMD Alpha Air
RF-76650      76MD  00534 62865  Russia - Air Force
RF-78765       76MD  00834 86590  Should be RA-78765 Aviacon Zitotrans
RA-78784       76MD  00834 89687  Now RF-78784  Russia - Air Force
76454     976/76LL   00734 69074  Gromov Flight Research Institute
76492        76LL   00434 52549  Gromov Flight Research Institute engine testbed
76746      76MD-M   00734 79374   Under modification at Zhukovsky
Syria ???       76MD  00534 60805  ex RF-76639  Syria - Air Force noted with 3 number reg in Arabic
X
X
#10588
I thought I had sent these a while back, they are using Factory codes too date, whether it will change I have no idea but if so would possibly be 15333* or 1B333*!
1F333A       78650   76MD-90A   001 02   Ilyushin OKB for Russia -Air Force  grey c/s
1F333B  RF-78651   76MD-90A   001 03   for Russia - Air Force
1E333C  RF-78652   76MD-90A   001 04   for Russia - Air Force (Miscode should be 1F333C)
1F333D  RF-78653   76MD-90A   001 05   for Russia - Air Force
1F333E  RF-78654   76MD-90A   001 08   for Russia - Air Force
X
Hi Ingo,
Mil tac added
Only one unknown identified 505C07,OM-BYB,11368,Fokker 100,Slovakia - Government Flying Service
