1 Member and 43 Guests are viewing this topic.
Good morning Alan, Saturdays unknowns:
3D2031  DEKLD (2x) Cirrus SR20 gts http://www.airnieuws.nl/movements/groningen/mar17/index.html
3E370C  DIMAU no luck with the details
One MIL: * 3E9A19  GAF007                                                         2017/05/20 09:53:59
3FD40E  DORSW (and today early morning / Sunrise watching from a HOB)  http://www.ballonsport-kurpfalz.de/unsere-ballone.html (not the owner/operator!) owner according to first website: http://www.ballontour.de/
3FF31A  DMFTG still no luck with the details
3FF531  DMWBG (2x) same with this one: still no details
3FF5AA  DMTCK no luck with the details
Have a nice day!
Regards Ingo
Good morning Ingo
3D2031,D-EKLD,,Cirrus SR20-GTS G2
3FD40E,D-ORSW,1197,Kubicek BB70Z,BA Ballontour,
Nothing on the others and mil tac added
jacobite
Good morning Alan, yesterday I input several aircraft into D/B explorer. I have just checked them and none of them show at all even when I do an update via the server they still do not show up, what am I doing wrong Alan? I can send you a list of the aircraft that I put in.
Send them to me Ianand I will check them out
jacobite
Quote from: Runway 31 on May 21, 2017, 09:28:05 AM
Here we go, EI-FWC, D-AXGD, G-TCDM, D-ABXF, G-EZPN, G-JZHG, D-AIXB, G-EZPK, N826NW, EI-FTJ, N831NW, G-EZPX,PH-EXM, D-ABGK, G-EZPN
TC-JVY, TF-SON, EI-FRO, VT-JEV.
That is what I have found so far Alan.
All in the d/b Ian some for quite a while.  How many records in your aircraft table, doing the update all records option should give around 247,000
jacobite
Quote from: Runway 31 on May 21, 2017, 09:59:27 AM
I have a total of 234,527 so it appears to be a lot missing. Should I do a full D/B update ignoring any thing that I have put in..
jacobite
#10613
Quote from: Runway 31 on May 21, 2017, 10:34:25 AM
I would suggest that
I have done that Alan and it shows D/B size 71177 which is what I had before so It does not appear that I am getting the current D/B info.
My D/B is showing the following info. Ac type 2569
Ac table 234518
A/Lines 5580
A/Ports 18485
Routes 322007
Mines is 92630 Ian.  I would suggest that you have more than one instance of Radarbox on your computer and it is going to the other one.  Easy way to find it is to use Windows search and swap them round about.
Michel
Alan,
CFG91 KPDX-EDDF
CND494 LRGP-EHAM
CND715 EHAM-LGKR
DTR433 GCFV-EKCH
EWG188 EDDK-MUHA
FHY831 EHEH-EHRD-LTAI
KLM1135 EHAM-EKCH
KLM1918 EPGD-EHAM
KLM943 EHAM-LIEE
PRI586 LPFR-EKCH
QTR273 OTHH-EHAM
SAS7821 ESGG-LEPA
SWR70T EHAM-LSZH
TCX228 EGCC-LTBS
TFL1XD EHAM-GCTS
TOM1GM EGNT-LCLK
TRA5901 EHAM-LGZA
TRA6K LIRN-EHAM
TRA6916 LIEO-EHAM
Michel
X
Alan/ian
My DB size downloaded today is 71177 like Ian, and everything is up too date including the latest IL76 updates Alan entered up till Thursday evening
X
Guess mines is wrong than X.  250,227 aircraft in the aircraft table and Navdata DB3 of 92,360Kb
hunter2021
#10619
FAA data error N123YD
Correct record N123YV
CONFIRMED
A06101
HK-4476
UE-123
Beech 1900D
SEARCA
