1 Member and 42 Guests are viewing this topic.
paul tricker
Unknown from Sunday
* 401A19  GBANX                                                          2017/05/21 17:08:10
G-BANX   Cessna F172M   0941   Oakfleet 2000 Ltd
Paul
ps
did a full update prior to this & have 250,227 in the aircraft table :-)
Thanks hunter, a miscoded miscode :-))
A06101,HK-4476,UE-123,Beech 1900D,SEARCA (Miscode hex of N123YD)
Morning Paul
401A19,G-BANX,F17200941,Reims F172M Skyhawk,Oakfleet 2000 Ltd,
Thanks for the confirmation and thanks again for the post
Ian/X
I would suggest that you have more than one instance of Radarbox software on your computer probably as a result of upgrading and not removing traces of the original versions from your computer and the update will be going to the original version.  Windows search for Navdata.Db3 will show you where they are assuming you have your computer set to open up hidden parts
X
Like you and Paul I have 250.277 in the aircraft table, I do not know why it shows 71.177 as DB size when yours is 92,360 but mine is up too date till Thursday evening when you entered some IL76's. Ian only had 234,518...that's way too low as I doubt you can enter 16,000 in a day!
X
Morning Alan,
Some local snippets :
c/n 2115 A321 EC-ITN is on lease to Avion Express as LY-VEG as shown in the d/b but is no longer operating for Condor but is now with Thomas Cook Airlines.
c/n 1777 A330 EC-MOU and c/n 1784 A330 EC-MOY both of Iberia have been painted in and are to be operated by the new low cost airline LEVEL.
jacobite
Quote from: Runway 31 on May 22, 2017, 07:43:55 AM
Ian/X
Thanks for all your help Alan, but I still have the problem. The Navdata.Db3 I have is from 2015 so I have no clue as to what is happening. What will happen if I remove that Db and reinstall from Db explorer.
Good to know that the correct one is being looked at by the software X but I presume that the one you looked at of 71,117Kb is not the one the software is reading and the correct one is located elsewhere on your computer
Ian,
If you can find the correct one on your computer all you have to do is drag and drop it into the correct location. and it will over right the old one.
X
When I go into the DB update and look for the latest update it tells me the size and today it says 71178, Fridays Il76 updates are not yet showing, but that is normal over the weekend. I have no issues and happy with the current db updating process.
X
As long as its working X, leave well alone!!.  Will have a look at Fridays IL-76's  in case I have missed them as they will show in the update the day following entry.
Got what you mean now X, yes the download is 71,117Kb in size but by the time it is processed and expanded the Navdata.Db3 file in your data folder is 92,630Kb in size
Michel
Alan,
AAL221 EHAM-KDFW
AAL751 EDDF-KPHL
BCS6892 EDDP-EGNX
KLM1919 EHAM-EPGD
KLM451 EHAM-OMAA
QTR8751 EBLG-ENGM-OTHH
Michel
jacobite
Quote from: Runway 31 on May 22, 2017, 10:16:42 AM
Ian,
Yuba duba doo it is now sorted Alan, I found the culprit and draged it to its proper home'
Thanks for all your help.
