0 Members and 26 Guests are viewing this topic.
Alan,
Not populating :
341654
Don't think it's EC-MJN.
CarlosAbreu
Morning Alan
I'll check locally some info about N155DC, if it isn't in the FAA database it can be the aircraft using his old MS by mistake and as LPCS is an airfield used by light and biz aviation is always a possibility this C150 flied over LIS area with the wrong data.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Nothing on that one Ian
CarlosAbreu
Thanks for FAA info.
Carlos
jim_stockwell
Evening Alan
Not populating was 3990c0 wiyh a flight I/d of FHEGA
sorry no other info and could not see it at45k.
Jim
Michel
Alan,
CND797 EHAM-LGRP
CSN604 EGLL-ZGGG
FHY611 LTBS-EGNM
GMI3727 GCRR-EDDW
NAX8YE ENGM-LFPO
RYR7KF LKPR-EIDW
TFL623 EHAM-LEPA
VKG1530 ENZV-LEPA
Michel
Hi Jim
Presumably its on delivery.  Nothing on the French register about it yet, hopefully updated soon
hunter2021
EX N228CC
A18720
YV3185
550-0133
CarlosAbreu
18-06-2017
JAF6DH (JAF636) LFQQ-GMAD
EVE5671 LPPR-GVBA
EVE5672 GVBA-LPPR
EVE5673 LPPR-GVAC
EVE5674 GVAC-LPPR
TCX85PU (TCX1351) GCLP-EGKK
TVF2KK (TRA150) LPFR-EDDM (Flight in database with wrong route)
PVG5771 LPPT-GMFO
PVG5775 LPPT-GCRR
PVG5776 GCRR-LPPT
MON233T (MON233) GCRR-EGKK
TCW5TM (TCW1646) EBBR-GCLP
CFG4PY (CFG1584) EDDM-GCTS (Flight in database with wrong route)
RYR12BC (RYR4088) EGCC-LPFR
JAF9AJ (JAF7873) EBBR-LPFR
VLG6599 LSZH-GCTS
BMS4057 LIMF-LPPT
BMS4058 LPPT-LIMF
TCW2DA (TCW1526) EBBR-GCRR
FPO826 GCTS-EGPD
RZO115 LPPT-LPAZ
ENT577 LPPT-LOWL (Flight in database with wrong route)
TAP3591 LEVC-LPPT
EXS18T (EXS218) GCRR-EGNM
Carlos
Good morning Alan, Sundays unknowns:
EWG9FK EW29 EDDC EDDK
3D3F68  DEWGM (2x)  https://www.flickr.com/photos/vriesbde/33575348540
3FF371  DMBAO (3x) http://www.rotorspot.nl/historic/d-2.php
3FF4E9  DMHCY still no luck with the details
3FF573  DMSOV http://www.dgfc.de/flugzeuge/vereinsflieger.html
A5611B  N446CB http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N446CB
Regards Ingo
Jim
Thanks to Tony on mode-s
3990C0,F-HEGA,50500312,Embraer EMB 505 Phenom 300
