0 Members and 27 Guests are viewing this topic.
Evening Alan,
I trust you enjoyed your game of golf in 36c heat !
VLG3153 : LEPA-LEJR
VLG3154 : LEJR-LEPA
VLG1457 : LEAL-LEST
VLG1456 : LEST-LEAL
ANE81GB : LEPA-LEIB
Michel
Alan,
AAL751 EDDF-KPHL
BMS5KP EGGP-LROP
CFG95 KPDX-EDDF
CND396 LGKR-EHAM
CND394 EHAM-LGRP
CND495 EHAM-LICC
CPA3123 EHAM-VHHH
DAL422 KJFK-EDDT
EXS46A EGNM-LCLK
QTR17 OTHH-EIDW
TFL8HX LBWN-EHAM
TRA5563 EHAM-EPKT
YZR7471 ZSPD-ZLXY-EHAM
Michel
Evening Ian
Yes was good if a tad warm, had to take my jumper off today!!
Hi Michel
Query regarding CND394 EHAM-LGRP. Can you confirm these details as even numbered ID's are normally inbound flight
Many thanks
CarlosAbreu
Today:
EVE455   LEMD-SKBO
ISS74NT (ISS7403) GCFV-LIMC
VOE2448   LFBD-LPFR
ENT578P   LPPT-LFPG (Ferri fkight ?)
TAP1116   LPPT-GCLP
TFL653   EHAM-GCLP
TVF5LT (TVF1502) EDDF-LPFR
TAP491M (TAP491) LFBO-LPPT
VOE22YY (VOE2220)   LFRS-LPFR
TRA7736   LPFR-EDDH
TVF05B (TVF1503) LPFR-EDDL
TVP7333   GCTS   -EPGD
JAF302P   EBBR-LPPT (Ferry flight ?)
JAF5XT (JAF4478) LFBD-GCRR
MON7988   EGKK   -GCLP
VOE9500   LFRS-LPMA
VOE9501   LPMA-LFRS
VOE9596   LFBD-LPMA
VOE9597   LPMA   -LFBD
VOE9598   LFCR-LPMA
VOE9599   LPMA-LFBP
JAF1HX (JAF4835) EBCI-GMMN
MON544U (MON544) EGCC-GCRR
CFG3LK   EDDS-LPMA
TUI254D (TUI6254) GVAC-EDDS
EXS92E (EXS1229) EGBB-GCFV
JAF50H (JAF4198) GCLP-EBCI (wrong routing in database)
EVE5402   LEMH-LPPT
TAP1466   LPPT-DAAG
TVP7332   EPGD   -CTS
IBK9489   GCLA-EGKK
EXS30G (EXS1230) GCFV-EGBB
BMS158 LPPT-LROP
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Thursdays unknowns:
3D284C  DENMY https://planefinder.net/data/aircraft/D-ENMY and https://www.planespotters.net/photo/350663/d-enmy-private-mylius-my-103-mistral
3D67DE  DFLOW got it: https://www.flickr.com/photos/greby-johann/34576341741/
3EC523  DKPPR (3x) no further information
3FEF1A  DMGHG AutoGyro Europe MTOsport [gyro] http://www.rotorspot.nl/historic/d-2.php
3FF354  DMCPD nothing new
3FF496  DMOZT https://www.luftfahrtclubbraunschweig.de/suchen.php?field=lfzreg&sopt=2&such=D-MOZT  https://www.planespotters.net/photo/224749/d-mozt-private-platzer-kiebitz
3FF4E9  DMHCY nothing new
3FF528  DMAKO (3x) no further information
3FF5BC  DMYDA (2x) no further information
ADA0F3  N9777 http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N9777
Regards Ingo
Morning Terry,
It is my intention to keep TE311 and the other members of the BBOM flight as they are.
The B412 is known as the Bell Griffin HT1 in RAF service https://www.raf.mod.uk/equipment/Griffinht1.cfm
Morning Ingo
3D284C,D-ENMY,0104,Mylius My-103/200 Mistral
3D67DE,D-FLOW,,Piper Meridian M500  - good catch
3FEF1A,D-MGHG,,AutoGyro MT-03
3FF496,D-MOZT,246,Platzer Kiebitz-B
3FF528,D-MAKO,D07G63,AutoGyro MT-03
ADA0F3,N9777,471,Lake LA-4-200 Buccaneer,Plane Fun Inc Tr Trustee
Nothing on the others
Many thanks
Terry,
My answer was relevant to the aircraft mentioned.  The other have been updated as well in particular the BBMF Spitfires have had the aircraft model details also amended.
Your input is most welcome and appreciated
Afternoon Alan.
IBK6786 : LEPA-LEMD
IBK6187 : LEMD-LEPA
IBK2WH : LEAL-ENGM
JAF42P : LEAL-EBBR
Afternoon Ian,
Presumably IBK6187 should read IBK6787?
Alan,
It should indeed. It's too hot to type when you're almost fainting with the heat !
hunter2021
A18720
YV3185 Cessna
550 Citation II
550-0133
Thanks again Terry,
One of the problems with the Wolfhounds is that they change between their mil serial and the civilian registration depending for example whether they are in theatre or not and remain on the FAA list while carrying  the serial i.e N525EF that you mention is current on the FAA list http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=n525ef   but can also carry 99-3106 depending on when and where you see it.  Sometime mil serial, sometimes civil reg.
