0 Members and 20 Guests are viewing this topic.
Morning Ingo
440998,OE-LUC,6254,Gulfstream Aerospace GVI (G650ER),Global Jet Austria
51407D,4L-TGU,190000064,Embraer 190-100AR,Georgian Airways on delivery
C0126F decodes to C-FGZM which is a Boeing Vertol Helicopter used for hauling timber in Canada.  The flight ID shows it to be one of the Discovery Air Defence Services Skyhawks so I presume it is a decoding error/corrupt packet
Mil tac added and nothing on the other one
Morning Terry, thanks again.
Regarding ZZ511 mil mode s also doesn't state that 43C758 is the correct one but it gives it for ZZ511 as well.  43C758 is the correct one and 43CB58 is the miscode.
Hello Alan,
decoding error / bad packet reception confirmed.
CarlosAbreu
Thanks for information, I checked C:\Users\UserName\AppData\Local\VirtualStore\Program Files (x86)\.... and there's s a lot of navdata.db3 with june date that I presume are the missing updates.
I'm going to desinstall ANRB software an reinstall it on root C:\Airnav.
Come to you soon
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Michel
Alan,
BMS1QQ LRCL-EGGP
BMS142 EGPF-LROP
EIN331 EDDT-EIDW
KLM47X EHAM-ENBO
KLM986 EGLC-EHAM
QTR20 EIDW-OTHH
Michel
CarlosAbreu
Finally it ANRB is working fine after a clean install on root C:\ Database Explorer is fully updated too.
Many thanks for you help.
Carlos
CarlosAbreu
TAP3590 LPPT-LEVC
IBS902P GCTS-LEMD
GMI6547 LPMA-EDDN
EZY1903 LPPT-GCTS
34310F EC-KHN A109 Agusta A-109E Power 11713 INR-Inaer
Carlos
Carlos,
Thanks for the route info.
I presume that you meant EC-KNH and not EC-KHN which is a VLG A320.
I have EC-KNH as now being CS-HIK since 2015 and checked the Spanish register 1/6/2017 and it is not included in it.  Possibly miscoding its old ID or register still to be updated
Morning Terry
Re N525EF, we standardize on US - Air Force and don't break down to individual operating units.  It also uses the serial 99-3106
Re N193LA I will keep it as ExcelAire as per the company itself https://www.excelaire.com/
CarlosAbreu
I track EC-KNH by MS code and and not from regist that was marked as unknown, later I check it in a database at http://www.airframes.org.
Miscode is always a possibility I check EC-KNH A320 from VLG too and MS code is different.
However is normal track this equipment (CS & EC) near LPPT due to LPCS proximity where helicopter cies are based and INAER operates as well in Portugal in emergency services.
Carlos
Thanks Carlos, I believe that it is CS-HIK miscoding its old hex, it is still with Inear or more correctly Babcock Mission Critical Services as they are now named since being taken over.
Afternoon Alan,
JAF7AB : GMMX-LIPE
Not populating :
34334A
Flight Id : GPM22G
Thanks Ian, nothing on your unknown
