0 Members and 17 Guests are viewing this topic.
Many thanks for the route info Carlos
Morning Ingo
Yes the good weather brings them out like flies.
All added apart from D-MLVD
Many thanks
#10908
Afternoon Alan,
EXS269 : EGNM-LEAL
EXS270 : LEAL-EGNM
IBE29RT : LEMD-LGAV
GMI3867 : GMFO-LFBO
GMI3866 : LFBO-GMFO
EZY9907 : EGCC-LEAL
EZY9908 : LEAL-EGCC
VLG6380 : LIMC-LEIB
VLG6379 : LEIB-LIMC
EXS58NC : LEAL-EGNT
EXS58AL : EGNT-LEAL
ISS280 : LEIB-LIML
ISS279 : LIML-LEIB
UAE9915 : DAAG-LEZG-SBKP  (The route actually starts in Dubai, but we'll take that as a given).
TAP1122 : LPPT-LEAL  (This would appear to be a new service operated by TAP Express ATR72. It is also on Monday's schedule)
TAP1123 : LEAL-LPPT
IBE29RT : LEMD-LGAV
CarlosAbreu
I'm going to manually change AT type and see what happens next time PR-XTC fly again over Portugal.
Since yesterday I'm catching MS 495299 (CS-???), I suppose it belongs to a new E190/E195 from PGA Portugália Airlines operating for TAP Portugal.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Carlos
It was added to the d/b last night so should populate and is in todays update
495299,CS-TTY,19000609,Embraer 190-200AR-195AR,Portugalia Airlines/TAP Express
CarlosAbreu
Thanks Alan, I'll do it right now !!!
Carlos
CarlosAbreu
#10914
I having here a problem.
I updated Database Explorer with "update all records (overwrite local database with server database)" box option checked and I missed all recente routing and aircraft data updates (?), the last record from this database update is 2015-10-26 (?) could you please help and explain what I'm missing ?
When you mean "populate" there's any other procedure ? How can I get a fully updated database.
Please advise.
Carlos
Carlos
How many aircraft do you have in your aircraft table.  I have 250,657 from yesterday I think I last updated
Assuming that the aircraft is in the database you can populate an aircraft on screen that is unknown to you by clicking on it.  You can also populate an unknown aircraft by MyLog/Tools/Populate, this method mat take a few tries to populate but leave for 10/15 seconds between tries.  You should have Auto-Populate Aircraft Data ticked in Preferences/Radarbox.
CarlosAbreu
#10916
I after last update today I have 234,520 rows at aircraft table, however during the update I saw reference to 250,693 aircraft (?).
Auto-Populate Aircraft Data is ticked in Preferences/Radarbox. At my log/tools I don't have "Populate" function, only "Refresh F5"
Why my local database isn't fixing server updates ? I t was supposed the update overwrite and make local database bigger with new data, I can't understand this, I'm using software version v6.01.001, is this the last one ?
Carlos
Afternoon Alan,
Norwegian Air International are using Smartlynx Estonia A320 ES-SAO c/n 936 possibly for the summer. Just left on IBK5314 LEAL-EGCC.
Michel
#10918
Alan,
BLX148 LEPA-ENGM
BMS3734 EGGP-LRCL
BMS3756 EIDW-LRCL
CPA3123 EHAM-VHHH
EDW10 LSZH-CYVR
EDW14C LSZH-CYYC
EDW19B KSAN-LSZH
EXS46A EGNM-LCLK
NAX277Y ESSA-LPPT
PRI458 LEMG-EKBI
SAS86L LEPA-EKBI
TCX228 EGCC-LTBS
TCX54GP EGCC-LGMK
TFL561 EHAM-LEPA
TFL623 EHAM-LEPA
TFL665 EHAM-GCLA
UAL195 EDDM-KSFO
VKG1581 LEPA-ENCN
VLG8418 EHAM-GCTS
YZR7479 ZHCC-EHAM
YZR7497 ZHCC-EHAM
Michel
#10919
Carlos,
It would appear that you have more than one instance of Radarbox software on your computer and when you download the update it goes to the wring instance.  Use Windows Search to look for all instances of NavData.db3 and drag the correct one into the data folder of the instance of Radarbox software that you are using.
If you click on MyLog third line down on the main screen above the centre of the map it will open up another window with Tools on the second line, click on tools and you will get a drop down list on which Populate is the 4th down the list.
