0 Members and 28 Guests are viewing this topic.
hunter2021
EX N550JE
YV3218
A70038
C550
Cessna S550
S550-0121
hunter2021
0D80D0
YV2392
Beech B200 King Air
BE20
BB-1966
hunter2021
424261
CP-2923
Boeing 737-7Q8
30642
BoA - Boliviana de Aviación (ILFC)
hunter2021
CODE ERROR
AAAAAA
YV1823
Cessna 402B Businessliner
402B-1349
CarlosAbreu
#10894
After checked all RVP regional flights operated by Do228 fleet the timetable is the following:
RVP951 LPBG-LPVR-LPVS-LPCS-LPPM
RVP952 LPPM-LPCS-LPVS-LPVR-LPBG
RVP953 LPBG-LPVR-LPVS-LPCS-LPPM
RVP954 LPPM-LPCS-LPVS-LPVR-LPBG
As ANRB Database Explorer only allows 1 stop, my sugestion is to exclude the less important ones (LPVR and LPVS) and post flights as:
RVP951 LPBG-LPCS-LPPM
RVP952 LPPM-LPCS-LPBG
RVP953 LPBG-LPCS-LPPM
RVP954 LPPM-LPCS-LPBG
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
hunter2021
Many thanks Hunter
AAAAAA is in the database as a Broken or Miscoded Transponder as it is used by a number of aircraft around the world
Do you have a hex code for HK4533
hunter2021
Quote from: Runway 31 on June 10, 2017, 07:38:17 PM
Many thanks Hunter
Maintains the same modes of ex FAC1164
hunter2021
EX N550JE
A70038
YV3218
S550-0121
CarlosAbreu
PR-XTC is marked as E50P instead of A359 in ANRB Database Explorer AT field. This aircraft is now in route from LEMD to SBGR as TAM8065.
Carlos
hunter2021
AB0212
ARBV-0212
Beech B200 King Air
BB-906
CarlosAbreu
IBS3615 LEAS-GCLP
VLG3286 GCRR-LSZH
PVG5662 GFMO-LPPT
TAP1558 GVSV-LPPT
TAP523J (TAP523) EDDV-LPPT
VOE24UK LFBD-GCTS
VOE2738 LFRS-GCLP
IBK2670 EGKK-LPFR
TAP1971 LPPR-LPPT
VLG3174 LFRS-GCTS
TAP1862 LPPD-LPPT
EIN93T (EIN493) LPFR-EIDW
PRW632 LPFR-ESSA
TAP9079 LPPR-GMFO
Carlos
Carlos
No idea Carlos, its OK on the server as you can see on the attached, no change since entered last year and OK in my Navdata as well
