0 Members and 85 Guests are viewing this topic.
Kenny
HS-CDY op Siam Winery Trading Plus Co. Ltd
4402B7 HS-BCM Diamond DA42 c/n 42.263  ex OE-FAL
Kenny
ANRB 3km north of VTBD
Morning Ingo,
Still nothing on D-MVGT and nothing on your miscode but the others all added in
Yes better to have a little too much than not enough but you can only do it for so long before the body and mind gets tired and complain.
#11750
Terry,
The company themselves use the names of the two companies as separate entities for example "Choice is not considered a luxury when flying with us. It is another benefit that comes as standard with ASL and JetNetherlands.
The company does not call themselves ASL JetNetherlands and in fact give details on the website of both company addresses and headquarters as follows:
Headquarter Address ASL
Voogdijstraat 29
B-3500 Hasselt
Belgium
AOC: B-3013
VAT: BE0461.940.625
Headquarter Address JetNetherlands
Thermiekstraat 22
1117BC Schiphol
The Netherlands
AOC: NL-AOC-38/57
VAT: NL8095.87.907.B01
In addition the website shows their bases and indicates whether for ASL or JetNetherlands http://www.jetnetherlands.com/en/about-us/bases  ASL even have one base in the Netherlands.
JetNetherlands aircraft operate using their JNL ICAO flight ID while the ASL ones operate using the aircraft registration.  Both airlines have separate Air Operator Certificates and again evidence of this is available on the website and indeed is shown above and until they merge their AOC I will be keeping them  separate.
I have added operator details for the aircraft you mention using the details obtained from my database
Good afternoon / evening Alan, Tuesdays unknowns:
3E0416  DHSTA (2x)  http://heli-thueringen.de/ueber-uns/flotte.html https://planefinder.net/data/aircraft/D-HSTA
3E49FC  DITFC decoding error
MILs:
* 3E8879  GAF640                                                         2017/08/08 07:17:20
* 3E8A15  THOR21                                                         2017/08/08 07:46:09
* 3EAE7B  NITRO10                                                        2017/08/08 07:48:05
* 3EB54E  LION77                                                         2017/08/08 08:07:50
* 3EB54E        2017/08/08 12:53:07
* 3EBDEB  LION76                                                         2017/08/08 08:08:15
* 3F6002  DASA06                                                         2017/08/08 10:21:04
* 3F6002  DASA06                                                         2017/08/08 12:41:47
* 3F6068        2017/08/08 08:08:05
* 3F6068        2017/08/08 09:56:04
* 3F6068        2017/08/08 13:34:15
* 3F6068        2017/08/08 17:36:52
   3F75D0  NITRO13                                                        2017/08/08 08:11:59
   3F9D8F  SCARE02                                                        2017/08/08 08:13:54
* 3FAC9E  NITRO11                                                        2017/08/08 08:37:55
* 3FB71F  SMASH43                                                        2017/08/08 14:24:43
Fingers crossed: until now no yellow or red cards sent by body or brain.
Regards Ingo
Afternoon Ingo,
All added in apart from the decode error
Evening Alan,
IBK5340 : LEAL-ENEV
VOE1313 : LEAL-LIPH
VOE1312 : LIPH-LEAL
CND313 : EHAM-LEAL
Evening Ian
Hope you are coping OK with the heat.
Alan,
Most we've had, so far, is 40C !
It's currently 21.30 and it's 30C. We're desperate for some of your rain.
CarlosAbreu
09-08-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
