0 Members and 61 Guests are viewing this topic.
Wednesdays unknowns:
3E686E  DKETA (2x)  https://www.planepictures.net/v3/show.php?id=173967 https://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?dsId=3547347
MILs:
  3E9667  ACES02                                                         2017/08/09 07:27:53
   3EB54E  LION                                                           2017/08/09 07:57:15
   3EB54E  LION                                                           2017/08/09 12:28:47
* 3EBDA1  MONSTR                                                         2017/08/09 13:56:09
   3EBDEB  PANTER1                                                        2017/08/09 07:40:21
   3EBDEB  PANTER1                                                        2017/08/09 08:54:16
* 3F7708  SW03TST                                                        2017/08/09 08:20:20
* 3F92AC  GAF833                                                         2017/08/09 12:51:46
   3FAC9E  NITRO1                                                         2017/08/09 13:30:35
   3FAC9E  NITRO1                                                         2017/08/09 18:50:50
   3FB71F  VADER11                                                        2017/08/09 08:13:26
   3FBE34  GAMG40                                                         2017/08/09 07:11:11
3FF5C1  DMVVY no further information
3FF5DC  DMPDV Dynamic WT9 operator/owner: http://www.fliegermosbach.de/verein/flugzeuge/vereinsflugzeuge/hk-36-superdimona-htt/
888147  PIC5710 https://xfw-spotter.blogspot.de/2017/07/a320-232sl-jetstar-pacific-airlines-d_25.html (already added I guess)
A1F7E2  N226GA http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N226GA
Have a nice day!
Morning Ian
3D1D92,D-EJLI,583,Bolkow Bo 208C Junior
Morning Terry
Many thanks
#11778
Morning Ingo
Friday
78124E,B-1001,7820,Airbus A321-231,Juneyao Airlines
42440D,VQ-BYK,17000037,Embraer 170-100SU,S7 Airlines
3F6F02,54+12,057,Airbus A400M-180,Germany - Air Force on delivery
Mil tac and others added but nothing on D-MXIK
Thursday
7811E2,B-8686,7810,Airbus A321-211,Sichuan Airlines added as you suggested
Mil tac added
Wednesday
3E686E,D-KETA,,ETA Aircraft Eta
3FF5DC,D-MPDV,,Aerospool WT-9 Dynamic,Fliegergruppe Mosbach
888147,VN-A571,7808,Airbus A320-232,Jetstar Pacific Airlines already added
A1F7E3,N226GA,2126,Gulfstream Aerospace G280,Bank of Utah Trustee/Gulfstream Aerospace
Mil tac added and nothing on D-MVVY
Many thanks
Thanks again Terry, looks like Skyservice are taking over the Canadian Biz jet market
CarlosAbreu
11-08-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Carlos, thanks again
CYYZGUY
40" LED Monitor
40" LED Monitor
Terry,
C-FPHS may well be owned by Skyservice but it is not in their fleet as it is operation with Pacific Sky Aviation as per the d/b.  Please have a look at http://www.skyservice.com/charter/ and you will see that there is no B735 in the fleet
The Swiss ones are on the Swiss register as operated by TAG Aviation not TAG Aviation Switzerland
CYYZGUY
JBU1523 No Routing
https://flightaware.com/live/flight/JBU1523
WA4348 No Routing
https://flightaware.com/live/flight/SWA4348
WJA678  No Routing
https://flightaware.com/live/flight/WJA678
THY6568 No Routing
https://flightaware.com/live/flight/THY6568  (Coming up as Turkish Airlines, I had no idea they had a 747, Picture shows Kalitta Air)
SWA5386 No Routing
https://flightaware.com/live/flight/SWA5386
BAW225 No Routing
https://flightaware.com/live/flight/BAW225
regards,
Jason
40" LED Monitor
40" LED Monitor
CarlosAbreu
12-08-2017 Updated file in attach.
Carlos
Good morning Alan, Saturdays unknowns
   3C6649  ISS23MJ                                                        2017/08/12 12:49:38
   3C6649  ISS2364                                                        2017/08/12 15:13:33
http://www.airfleets.net/ficheapp/plane-b737ng-36881.htm  https://www.planespotters.net/airframe/Boeing/737/D-AIRI-Meridiana/oxLOhO7N
* 40066E  BCS2518                                                        2017/08/12 02:37:38
* 40066E  BCS101                                                         2017/08/12 20:56:23
caused by
   40066A  BCS2518                  G-BMRH     B752  DHL Air              2017/08/12 02:31:38
   40066A  BCS101                   G-BMRH     B752  DHL Air              2017/08/12 20:37:31
Unfortunately I'm not able check if the 40066E entries are caused by decoding errors/bad packets received ore by a dodgy box. Reason: Unable to connect to PC as since creators update Teamviewer doesn't start as it should at every reboot of the system.
8467A0  VNL13VA https://a320archive.com/msn/7816 https://xfw-spotter.blogspot.de/search/label/7816 (already added I guess)
Have a nice Sunday!
Regards Ingo
Morning Ingo,
3C6649,D-AIRI,36881/3671,Boeing 737-86J,Meridiana I had added it in previously under the wrong hex
40066A is the correct code.  40066E is wrong probably corrupt packet as it is G-BVNN B734 with Comair in South Africa
8467A0,JA13VA,7816,Airbus A320-214,Vanilla Air added soon after departure from XFW
