0 Members and 26 Guests are viewing this topic.
CYYZGUY
40" LED Monitor
40" LED Monitor
Terry
OY-UCA, All the information I can find shows that it is operated by Himmark Air as per the d/b.  I t may even have been re-registered to Austria but confirmation awaited.  What is your source detailing Air Alsie
OY-CKK all the information I have is that it is owned by Kirbii Invest and operated by Air Alsie as per the  d/b
OY-CLS became F-HPVE on 22/6 and the database has been updated to reflect this change
Jason,
1st batch, regarding the THY flight.  With the limited information provided I can only presume that THY have leased a 747.  If you provide some information on the aircraft concerned such as hex code this would aid identification
Second batch done Jason, thanks again
Hawkeye
Afternoon Alan,
Just logged 404CC9 with c/s G-CDBA. Comes up as Best Off Sky Ranger with that reg on Planefinder.
Syd
Terry,
Some of it is out of date when OY-CLS has been sold on.  I would imagine that they like most charter companies operate aircraft owned by others when they do not require them.
G-RVIB added
Regarding D-CAAL see http://www.arcus-air.com/arcus-air-logistic/dornier228/ but removed the hyphen
D-AUCR owned by  Nalex Co, operated by DC Aviation
Afternoon Syd
404CC9,G-CDBA,BMAA/HB/406,Best Off SkyRanger 912,Peter John Brennan
54901 - Jim
Hello, Alan!
For your missing list ...
A876C3 / N6442P
A02AB6 / N11JV
A2EC39 / N288FJ
A3C05B / N3405F
A149AC / N182SB
A9E7F5 / N7374E
3CE624 / D-COLO
A1653B / N18950
A4F2EC / N418MA
A9C3ED / N7282L
A99B57 / N718SB
AAFE70 / N8071Y
A246F8 / N246H
Thanks!  Jim
KOSH - Oshkosh, Wisconsin USA
Terry
D-ISUN now in the d/b as d/b http://www.challengeline.de/fleet_jet.htm
D-CUBA Scholz AG
D-IURS http://www.eurocontrol.int/rmalive/operatorList.do
Don't believe what you see listed for photos, better to check the info from reliable sources like the operator if possible
I don't think users will be overly concerned whether it is Ltd or Limited
Hi Jim
Nice to hear from you stranger.
Nothing on N246H last holder shows as being de-registered in 1947!! on FAA but all others added
Many thanks
Evening Alan,
Found this for N246H. Appears to be relevant as the hex code of A246F8 is given. It does state the AOC expired on 31/05/2017.
http://es.flightaware.com/resources/registration/N246H
Hi Jim
Its the same aircraft as on Flightaware but RV6A c/n 24461 is AB501F N828RW and has been that since 30/05/2014 http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=828RW  so I guess that it is using its former hex and registration and added in  as a miscode.
Terry,
AG and KG are the same thing, different countries but it is KG as per the d/b
No idea on GAS, don't think its the same company as no aircraft are mentioned on their website and as far as I am aware they are an FBO, got it from my d/b, they also had 2 Learjets previously.  As Eurocontrol have DC aviation as the operator I will change it the other way around
CarlosAbreu
13-08-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
