1 Member and 29 Guests are viewing this topic.
CarlosAbreu
26-09-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
yang
The aircraft type of Mode S 899078 is AT76, not B738.
Jay
Good morning Alan, Tuesdays unknowns:
MILs:
* 3F493F  BU01                                                           2017/09/26 08:27:23
* 3F493F  BU01                                                           2017/09/26 15:12:47
   3F4A09        2017/09/26 12:24:42
* 3F565F  BOMBER                                                         2017/09/26 08:10:19
3FF5D6  DMCDG  no luck with the details
Regards Ingo
yang,
As can be seen from the attached 899078 B-28066 was added into the database as an AT76 after the aircraft departed EKBI on 22/9 on delivery.  Maybe an update to your Navdata is required to confirm this update
Many thanks
Hi Ingo
Mil tac added but nothing found on your unknown
X
New Czech unknown in MOW area climbing to 41000ft
* 49D26F        2017/09/26 16:24:18
X
X
According to the Czech online register this was last used by L410 OK-SDS c/n 2803 which was cancelled in 2011, nothing allocated with the hex since and I don't know the new ID of 2803
X
I saw OK-SDS pinging on FR24 yesterday, west of Moscow, so must be the L410, height was 4100ft (NOT 41,000ft) so does makes sense, but like you can find nothing on the internet re its new reg.
X
It may possibly be with the Russian Air Force X
Good morning Alan, Wednesdays unknowns:
MILs:
* 3EA5C3  STRIKE                                                         2017/09/27 18:45:02
   3EA83D  GAF073                                                         2017/09/27 12:14:31
* 3EB6A5        2017/09/27 07:50:45
* 3F4DE5  PIRAT                                                          2017/09/27 07:49:41
* 3F4DE5  PIRAT                                                          2017/09/27 08:51:27
* 3F4DE5  RAPTOR                                                         2017/09/27 12:46:02
* 3F4DE5  RAPTOR                                                         2017/09/27 13:57:50
* 3F6682  GAF152                                                         2017/09/27 11:40:17
3FF109  DMBFB no further information
3FF5D6  DMCDG (2x) nothing new to report
3FF5E7  DMAES Kummerle Mini-Fly-Set 730/85-3 https://www.lph2o.com/aircraft-database?clearfilters=0&clearordering=0&resetfilters=0
781147  CSN061 A333 on delivery / already added I guess.
Regards Ingo
CarlosAbreu
27-09-2017 Update file in attach.
Carlos
Mil tac added
3F6682,54+11,054,Airbus A400M-180,Germany - Air Force on delivery
781147,B-8361,1814,Airbus A330-343E,China Southern Airlines
3FF5E7,D-MAES,730/85-3,Kummerle Mini-Fly-Set
Nothing on the others
