0 Members and 41 Guests are viewing this topic.
Good morning Alan, Fridays unknowns:
395E9C  FJBPI (only information containing F-JBPI: https://abpic.co.uk/pictures/view/1566138)
MILs:
* 3E8B41  GAF156                                                         2017/09/29 10:44:15
   3E93FB        2017/09/29 13:50:14
* 3F99AD  GAFK31                                                         2017/09/29 10:47:27
   3FBC7C  GAF036                                                         2017/09/29 08:40:14
   3FBC7C  GAF036                                                         2017/09/29 10:58:29
40017A  LLM9511 VP-BWO https://www.planespotters.net/airframe/Airbus/A321/VP-BWO-Aeroflot-Russian-Airlines/ol52u0NK http://www.airfleets.net/ficheapp/plane-a321-2337.htm
781149  CSN001
896484  UAE5GT https://xfw-spotter.blogspot.de/search/label/0244
Regards Ingo
Hi X, it is and added into the d/b yesterday afternoon
781149,B-8363,1818,Airbus A330-343E,China Southern Airlines
I am presuming 400151 to be a corrupt packet with a few messages received rather than a miscode
7C0639 decodes to Tiger Moth VP-BIJ which is still current on the Aussie register today
Hi Ingo
395E9C,57BRZ,,JMB VL-3 Evolution
40017A,VP-BWO,2337,Airbus A321-211,Yamal Airlines ex Aeroflot WFU 15/8 stored Kaunus and was ferried to Maastricht yesterday for painting
781149,B-8363,1818,Airbus A330-343E,China Southern Airlines on delivery
896484,A6-EUZ,244,Airbus A380-842,Emirates on delivery
Mil tac added although one may have been A400 54+13 on delivery from Seville
Morning Terry, thanks again
X
I do not think a Tiger Moth would be climbing to 41000ft so one can only assume it is a wrong code but I had 30 pings over 7 minutes, nothing else was in the area that it could be mixed up with it....unless Russky Mils have started using Aussie codes we have another mystery...Hahaha
Both 400151 and 400159 were pinging at the same time on my box for 17 minutes at 34000ft heading North towards LED. I had 130 pings from the 'miscode' and 1030 pings from 400159 but I have picked 400151 up 10 times this year. The aircraft was in clear line of sight so I have to believe it was 'double' pinging.
X
X
* 424378  AFL7605  LKMT-UUEE                                             2017/09/30 14:36:16
424378 should be VP-BLN A320-214 Aeroflot c/n 7843 on approach to SVO on delivery
X
#12292
X
The Aussies don't put new aircraft on the register until they actually arrive on Aussie soil so I will watch the register for an update.  The fact that it didn't show a flight ID same as 400151, leads me to believe that it is not as it seems but time will tell.
Does 400159 double ping on every occasion you pick it up or only occasionally.
424378,VP-BLN,7843,Airbus A320-214,Aeroflot Russian Airlines  Internet crap here so don't have the Airnav network so relying on posts for new ones but nothing on this one until your post
X
400151 does not ping everytime 400159 is around. I picked up 400159 four times yesterday but 400151 only once. I have picked up 400151 10 times and 400159 about 100 times this year, so only occasionally do I get this double pinging. Will look out for 400151 next time it shows up and see if 400159 is around.
X
Cheers X, added it in anyway as a miscode
Evening Terry, thanks again
Alam
Good morning Alan, Saturdays unknowns:
0D0AA3  AIJ3001 AIJ: ABC Aerolineas https://xfw-spotter.blogspot.de/search/label/7879 already added I guess
424378  AFL7605 https://xfw-spotter.blogspot.de/search/label/7843 already added I guess
4CC4D5  WOW753 (2x) WW753 was -according to DUS timetable- operated by TF-BRO A320. According to our db TF-BRO shall use 4CC4D3. I've received it two times on two boxes with hex 4CC4D5.
Have a nivce day!
Regards Ingo
Morning Ingo
0D0AA3,XA-TEA,7879,Airbus A321-211,Interjet
Yes several reports received yesterday of TF-BRO miscoding, so added in as such
CarlosAbreu
30-09-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
