0 Members and 26 Guests are viewing this topic.
GreekSpy2001
#12315
  A9DB8D  BSK052P                  N734SX     C172  William K Chambers   2017/10/03 08:02:15
   A9DB8D  BSK053                   N734SX     C172  William K Chambers   2017/10/03 13:24:06
But just visually ID as a Boeing 737.  Any ideas what it should be?
Graham
PS  just seen this report on the Mode S Yahoo Group
A9DB8D N732MA B738 30618/830 Miami Air BSK634 32100 36000 316 11:09 11:23
CarlosAbreu
Some flights from "Monarch Operation" aren't using "P" code for Ferry/Position flight, as I can't confirm that statment, PAX can be on board, in accordance with real callsign from aircraft, please correct the following data from 02-10-2017 list:
New record:
AWC1086 EGKK-LPPR
Changes:
BAW8629 LPFR-EGBB to EGBB-LPFR-EGBB
BAW8607 LPFR-EGBB to EGBB-LPFR-EGBB
BAW8612 LPPT-EGKK to EGKK-LPPT-EGKK
BAW8640 LPPR-EGBB to EGBB-LPPR-EGBB
From now on all flights from "Monarch Operation" uses this criteria, identified ferry flights are in the list for information purposes but not posted in ANRB database.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Graham
N732MA is miscoded on one box and is giving the hex code for the C712 when it uses that one.  You will notice it is correct on the other box.
Hi Carlos,
I would imagine the Monarch repatriation flights will be a one time use flight ID so I wouldn't bother much about them.
CarlosAbreu
03-10-2017 Updated file in attach.
Carlos
Morning Alan, Tuesdays unknowns:
505C57  ELJ401 ELJ: Elite Jet possibly bad packet received / possible source: 505C53 OM-BLS
758521  RPC8960 RP-C8960 ex. HB-IYZ http://www.skyliner-aviation.de/regdb.main?LC=nav4&page=2
X
#12321
This miscoding Nordwind has just departed SVO apparently en route Punta Cana, Dominican Republic. No idea of type as visibility is poor. Nothing on SVO departure boards and no obvious miscode apparent.
* BDBC7C  NWS3517  UUEE-MDPC                                             2017/10/04 11:59:05
X
X
In the current political environment it was rather strange to see this coming into MOW on an Open Skies f/n! It might have been here bringing the new US Ambassador to town.
AE08D5  OSY12T                   61-2670    C135  US - Air Force       2017/10/02 15:48:52
AE08D5  OSY12F                   61-2670    C135  US - Air Force       2017/10/04 09:58:54
X
Hi Ingo
758521,RP-C8960,E3338,British Aerospace AVRO 146-RJ100,Royal Air Charter Service on delivery out of Cranfield
No idea on the Elite Jet but if its a corrupt packet the flight id will show with the correct code in mylog
Morning Terry, thanks again
X
No idea on the Nordwind, nothing sticks out as a possibility
There were Russian open skies flights over the UK just before I came out to Spain.  Seems everything keeps going as per the current agreements
X
* 15213F        2017/10/04 12:55:43
15213F decodes to RA-74047 which I had as ST-PRC An-74 36547097941 Government of Sudan.
X
X
My d/b shows that it was with the Yu Ye Sedakov Measurement Systems Scientific Research Institute until March when it was WFU so I guess it is back flying again
X
Nothing surprises me out here anymore......aircraft WFU for ten years can come back into service at any time as was the case with a YK42 the other day!
The Russians have RA-74047 as NIIIS - Research Institute of Measuring Systems so I assume the Yu Ye Sedakov is the name of a man the institute is named after. Should have looked this up before I bothered you (my An-72/4 file needs serious updating>>>I have only just finished the props)
X
