0 Members and 21 Guests are viewing this topic.
X
Still not idea on the Nordwind.  Doubt if the route info is correct as it is from 2014
X
Well wherever our miscoding Nordwind went it was last noted by me South of Greenland heading SW toward Newfoundland, still a long trip in a B738 from SVO.
X
CarlosAbreu
Please change the following flight code entry:
AAF923F LFPO-LPMA to AAF923 operated by A320 F-HBAP.
It's confirmed that the following flight from this aircraft was a"Monarch operation" (AAF741 LPMA-EGKK), but as Aigle Azur operates regular flights from Paris to Madeira it was impossible to check if AAF923 was a ferry flight as I was initially informed.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Will do Carlos, tanks again
paul tricker
A31F94  N300CR                                         2017/10/05 18:20:04
N300CR  Falcon 7X   29   Crane Co
Paul
Thanks Paul, added it in this morning
Aerotower
Can you correct this database error: G-UZHB as A20N but it is a A320.
Best Regards,
Manuel S.
Good evening Alan, Thursdays unknowns:
MILs:
   3EA50F  GAF007                                                         2017/10/05 10:45:07
   3EA50F  GAF007                                                         2017/10/05 14:20:18
* 3F40D8  BURNER1                                                        2017/10/05 13:56:48
   3F4410        2017/10/05 13:47:01
* 3F7430  COLT2                                                          2017/10/05 18:03:33
45BA07  NFA124P Fairchild SA227DC   DC-896B   (ex: VH-TWL)  http://www.amcarusa.com/various.htm
4AB538  SEMIX PILATUS PC 12/47E   1731 (ex: HB-FST) http://www.amcarusa.com/various.htm
A88D56  N650GF http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N650GF
Regards Ingo
Manuel
No error.  G-UZHB is an Airbus A320-251N which makes it an A20N as per the database and as per the UK CAA http://publicapps.caa.co.uk/modalapplication.aspx?catid=1&pagetype=65&appid=1&mode=detailnosummary&fullregmark=UZHB
Evening Ingo,
The mil tac added and your 3 unknowns were added earlier in the day
CarlosAbreu
06-10-2017 Update file in attach.
Carlos
