0 Members and 21 Guests are viewing this topic.
Morning Alan, Fridays unknowns:
3C44A1  DAAEA perhaps on its way to become EI-HEA https://www.planespotters.net/airframe/Airbus/A330/D-AAEA-EAT-Leipzig/Lqdtgq
3E5930  DIYYY https://planefinder.net/data/aircraft/D-IYYY
MILs:
* 3E8B57        2017/10/06 07:43:35
* 3F5C12  PIRAT1                                                         2017/10/06 08:04:41
45BA07  NFA125P perhaps I received it again before you have added it in. Reception time:  11:45 UTC
ADC238  JBU6994 http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N986JB already added I guess
Regards Ingo
Morning Ingo
3C44A1,D-AAEA,116,Airbus A330-322(F),ASL Airlines Ireland up from Dresden for an air test after freighter converson
3E5930,D-IYYY,402C0461,Cessna 402C,Aerowest Photogrammetrie H Benter
Mil tac added.
Correct the NFA was added 1338 and yes the JBU also added yesterday afternoon
X
John Hargreaves advises that is VP-BJL miscoding BDBC7C instead of its allocated 424383
X
#12364
Thanks to all, I did not think it would be a B73H going the distance to Punta Cana and back unless it refueled in Newfoundland near where I lost it, but it was on departure board as a B73H going to Simferopol yesterday, the weather did not allow me to look at it either day otherwise I would have known the type! Today it is on the way to Montego Bay again I could not see it
X
CarlosAbreu
New B738 from Ryanair not listed in database operating as RYR74MK (RYR7418) LFOB-LPFR:
Mode S: 4CEA11
Regist: ?
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Unknown Belarus picked up near MOW
* 510097        2017/10/07 16:09:33
X
Carlos,
I don't have any information on it but I would wager it is EI-EKR miscoding.  I has used 6 or 7 different ones in the past
CarlosAbreu
After I read your post I checked this and you're right, EI-EKR is using several codes.
Thanks for clarify situation.
Carlos
X
510097,EW-449TH,1013405167,Ilyushin IL-76TD,Ruby Star Airlines its in the d/b under a couple of miscodes so looks like it has finally got its boxes sorted
Thought it might be Carlos, its similar to other miscodes it has had.  They have been trying to fix it for years and keep on messing it up
paul tricker
One from today
* 4B199B  HBJSD                                                          2017/10/07 11:30:53
HB-JSD  Falcon 8X  404  Dasnair
Paul
Paul
4B199B,HB-JSD,404,Dassault Falcon 8X,Dasnair,
CarlosAbreu
07-10-2017 Updated file in attach.
Carlos
Good morning Alan, Saturdays unknowns:
One MIL:
* 3F5067  GAF047                                                         2017/10/07 11:25:14
* 3F5067  GAF047                                                         2017/10/07 13:48:44
800C52  VTBVV  some information, but no details: https://flightaware.com/live/flight/VTBVV
Have a nice day!
Regards Ingo
