0 Members and 17 Guests are viewing this topic.
Michel
Alan,
ABW205 UUEE-EHAM
ABW206 EHAM-LIMC-UUEE
AFR98UU EHAM-LFST
BEE6AV EDDT-EGFF
BLX182 GCTS-ESGG
CAI2V LTAI-EHAM
CFG2EC GCRR-EDDH
CFG6WH GCFV-EDDH
IBK3675 GCTS-EKCH
IBK5072 LEMG-EKCH
JTG710 GCTS-ESMX
JTG968 GCTS-EFVA
KLM63F EHAM-EPKK
RYR4364 EGPK-EPRZ
RYR4ZC EGNX-EPKK
SAS31A ESSA-EGLL
VKG1837 GCTS-ESGG
Michel
CarlosAbreu
07-11-2017 Update file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
#12707
Hi Terry,
At this time the FAA still show it as a plain old 790 by the way.  Apart from 737 300/400 conversions we have standardised to F for pure built freighters and SF for conversions.  The 300/400's change to F when converted.  For example there are 747 conversions which I have seen with BDSF but we don't use the BD designation on them either as there are conversions centres other than Bedek/BD.
I will need to try and find a copy of the STC to see what the actual designation is given for the variant
Morning Michel,
Thanks again.  BTW the RYR W17 details were added to the d/b on Saturday and the BEE details on Monday so hopefully there will be no further blank route details picked up from them
Carlos, for some reason the sheet is not downloading this morning
Morning Alan,
Something not quite right here. I sent you the details for EC-YSO c/n 96009-959. These details on AN have come up showing a silhouette of a presumably motorised hang glider with 'ULAC' in the aircraft column. However, a search of the registration on google gives the following photo and details :
https://www.jetphotos.com/photo/8326771
CarlosAbreu
Here it goes again with some 08-11-2017 entries.
Carlos
Ian,
Can you access the ICAO DOC 8643 website and update me as to its ICAO CODE as I cannot get the page to open.  I don't believe it has been issued with a code therefor it will either be allocated ULAC or ZZZZ.  As its MTOW is 450kG this puts it in the ultralight category therefore its code is ULAC.  See http://publicapps.caa.co.uk/modalapplication.aspx?catid=1&pagetype=65&appid=1&mode=detailnosummary&fullregmark=CBVF for details on a British registered Maverick.  Unfortunately ULAC covers varying types of aircraft and the logo may not be representative of every type covered by the code. I am unable to change the silhouette for a ULAC and I suggest that if you don't think that the silhouette is suitable for your needs you may want to make a suitable replacement one that does.  Alternatively you may want to change its code in your Navadata to ZZZ and you will get a question mark logo instead.
Many thanks Carlos I got it to open this time round.  For your information the dates for Tuesday and Wednesday need changing
Afternoon Alan,
After much pfaffing around, I have found the FAA document concerned. I put in 'Control F' and searched for Maverick and designator 'MAVR' has been highlighted. For yourself and anyone else's perusal particularly Rod for silhouettes or equivalent it's here. Just scroll down.
https://www.faa.gov/documentLibrary/media/Order/2017-10-16_Order_7360.1C_Aircraft_Type_Designators.pdf
Good afternoon / evening Alan, Tuesdays unknowns:
3CE7EB  DCPDB http://www.airforcesmonthly.com/2017/08/07/germany-leases-m28-skytrucks/
3D23CD  DELUR (2x) nothing new to report
MILs:
* 3F41CE  PANTER2                                                        2017/11/07 14:31:33
* 3F44A4        2017/11/07 06:48:39
* 3F4AEE        2017/11/07 09:33:15
* 3F54DE  SW03TEST                                                       2017/11/07 13:54:06
* 3F6CC1        2017/11/07 09:00:17
* 3F6CC1  RAPTOR                                                         2017/11/07 13:12:38
* 3FAFA8  KNIGHTT                                                        2017/11/07 10:02:44
* 3FAFA8  KNIGHTT                                                        2017/11/07 11:49:49
* 3FAFA8  GHOST2                                                         2017/11/07 14:49:57
   3FBC7D  GAFE22                                                         2017/11/07 14:42:10
741E50  AWS801 https://planefinder.net/data/aircraft/JY-GRP
regards Ingo
#12717
Hi Ian/Alan
Interesting document, but I use https://www.icao.int/publications/DOC8643/Pages/Search.aspx which is working fine for me, and they do have MAVR for the AEA Maverick
EDIT just seen AEA's website - https://web.archive.org/web/20051026195526/http://www.aeroengaus.com.au/aircraft.htm - the Jetphotos hoto that Ian links to is a very different aircraft... discuss!
Rod/Alan,
I think the best idea would be to use 'ZZZZ' as the type designator. It is certainly a bit confusing. I wish I had never picked up the thing now :)
#12719
Afternoon Ian/Rod
I don't believe its the same aircraft.  A Google search for AEA Maverick shows https://en.wikipedia.org/wiki/AEA_Maverick and note its a one seat design and it is stated only one was built while the Murphy Maverick shows as a two seat design https://en.wikipedia.org/wiki/Murphy_Maverick.
I note that in the line under the AEA Maverick there is the MVRK which is the Phoenix Maverick a German licence built version of the Murphy Maverick as per its Wiki entry which would lead me to believe that the Murphy Maverick should also be MVRK but I have not found it yet on the FAA List.
I use that link as well Rod bit cant get it to open possibly because of my crap internet here.  Can you search using Murphy Aircraft to see which of their models show please.
