0 Members and 35 Guests are viewing this topic.
Evening Ingo
71C231,HL8231,33975/1716,Boeing 737-85P,Eastar Jet
Michel
Alan,
ABW342 KATL-EDDF
CFG9WC GCTS-EDDH
DLH3NF EIDW-EDDM
EXS466 LCLK-EGNM
JTG258 GCTS-EKCH
JTG750 GCLP-ESNZ
PRW325 ESGG-GCLA
Michel
CarlosAbreu
09-11-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
M
SAS1498   EKBI   ESSA
LOT8129   EETN   ESGG
LOT8180   EBBR   EETN
FIN5YP   EFRO   EFHK
FIN1437   EFHK   EDDT
FIN1438   EDDT   EFHK
WZZ2465   LHBP   ULLI
WZZ2466   ULLI   LHBP
WZZ1450   EVRA   ENTO
RYW6856   OJAQ   EFHK
RYW6857   EFHK   OJAQ
TAY56   ZHCC   EBLG
TAY57   EBLG   ZHCC
NTJ307F   ESNO   ESSA
NTJ316F   ESSA   ESNO
NTJ317F   ESNO   ESSA
BRX274L   ESSB   ESNU
LBT812   DTMB   ULLI
LBT813   ULLI   DTMB
GEC8404   EDDF   ZSPD
GEC8405   ZSPD   EDDF
MYX593   EETN   GMAD
MYX594   GMAD   EETN
CLX978   ELLX   ZHCC
AZG789   KORD   UBBB
NVR555   EFHK   GVAC   via ESSA
NVR556   GVAC   EFHK   via ESSA
502C84 , YL-RAI , AT72 , ATR 72-202(F) , RAF Avia , 493
jacobite
Hi Alan, are you well? I seem to be having a problem when I manually input new routes, when I go back to the inserted route it has gone.  I am putting the new route in correctly. What is the cause of this problem. Example KLM26X, FIN1BA, EXS85E & EZY42BK.
Doing fine Ian.
I have no idea how you are adding them in so cannot comment.  The flights you mention are in the database.
jacobite
Quote from: Runway 31 on November 10, 2017, 12:02:28 PM
Doing fine Ian.
Would it make it more sense to download the data base that will override my manual updates.
Good evening Alan, Thursdays unknowns:
0D0AA7  AIJ7901 hopefully already adeded: https://xfw-spotter.blogspot.de/search/label/7903
MILs:
* 3E8395  POLICE                                                         2017/11/09 18:12:58
* 3E8AD4        2017/11/09 13:10:55
* 3E9B9F  LANCE1                                                         2017/11/09 08:23:16
* 3E9B9F  JUDGE1                                                         2017/11/09 13:08:58
* 3EA1B4  GAF628                                                         2017/11/09 08:43:38
* 3EA1B4  GAF628                                                         2017/11/09 11:36:58
* 3F83A7  GAF218                                                         2017/11/09 08:26:27
* 3F83A7  GAF218                                                         2017/11/09 17:25:09
* 3F9D83  GAFS01                                                         2017/11/09 11:52:15
471A77  HAKAP http://www.avia-info.hu/talalat.php?Ujtipus=2223 / http://www.eurocontrol.int/rmalive/regulatorExport.do?type=xls
Regards Ingo
CarlosAbreu
10-11-2017 Update file in attach.
Carlos
orkney
Thanks for them Carlos and Ingo
Andrew
orkney
Hello Terry
Thank you for that one.
Andrew
Hi All.
Just to inform you that Alan (Runway 31) will be offline until Tuesday evening whilst he travels back to the UK. Orkney will be looking after things until then.
Thanks,
