0 Members and 24 Guests are viewing this topic.
jacobite
Good morning Alan,
I am still not having much luck with the routes, I have added every which way I can and still no luck I tried what you suggested and still no luck..
Good morning Ian
Unfortunately I cannot see what you are doing to advise regarding manual updates and cannot see why what worked previously is not working for you now.
There is always the option of a database update
jacobite
Quote from: Runway 31 on November 18, 2017, 09:31:52 AM
Good morning Ian
Thanks for your quick reply. I wish it was something simple to sort out Alan. I have updated the database several times and still end up with the same problem even when I input the routes manually.
What size is your database, how many rows in the aircraft table?
jacobite
Quote from: Runway 31 on November 18, 2017, 10:32:23 AM
Database size 322018
Aircraft table rows 234522
Todays update gives me 257369 rows so it looks like your updates are going somewhere else.  You must have another instance somewhere on your computer so you will need to search for the correct one and move it into your working folder
jacobite
Quote from: Runway 31 on November 18, 2017, 11:34:32 AM
I will trawl through my files and see if I have any other ANRB showing. I will let you know Alan.
Evening Terry.
N1901G, there are spaces on FAA
SA341 is only for Aerospatiale built Gazelles and has been omitted
WA after the c/n is quite important as it details Westland built as opposed to Aerospatiale built
The is actually a space after the M  for the Chinooks but I have left it out.
X
This Chinese was inbound but do not know if B3333 refers to a reg or B3 c/s
* 7812D1  B3333                                                          2017/11/18 15:29:41
X
I have not info on it X apart from it is B-3333 and it arrived from Shanghai
Terry, yes my d/b agrees re the Chinooks and the FAA has the spaces for that one as well.
X
The only reference I can find to a B-3333 is this but was dated 2012!
Evergrande Real Estate Group Airbus A319-133 (ACJ) D-ALHT (B-3333) (msn 4428)
X
CarlosAbreu
18-11-2017 Update file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Fridays unknowns:
3C0859  SDR3260 (2x) SDR: City Airline (Sweden) D-ASEE http://www.airfleets.net/ficheapp/plane-a320-4953.htm
3D23CD  DELUR https://www.flugzeugforum.de/threads/flugbetrieb-rostock-laage-etnl-rlg-2017.86300/page-59 http://cirrusaircraft.com/aircraft/sr22/
MILs:
* 3E8C00  RAGE                                                           2017/11/17 08:47:21
* 3E8C00        2017/11/17 10:09:27
* 3F4F5F        2017/11/17 08:50:37
* 3F4F5F        2017/11/17 09:55:08
* 3F5727  GAF462                                                         2017/11/17 12:16:32
   3F5D23  COLTT                                                          2017/11/17 08:23:41
* 3F61B7  GAF094                                                         2017/11/17 10:20:46
* 3F767A        2017/11/17 08:40:18
* 3F767A        2017/11/17 12:49:28
* 3F7F23  GAFE14                                                         2017/11/17 09:34:38
* 3F8A2E  BULL2                                                          2017/11/17 08:07:11
* 3FA789  GAF164                                                         2017/11/17 15:41:08
3FECCC  ZZZZZZZ nothing new to report
48952E  SPFKO (2x) https://www.planepictures.net/v3/show.php?id=1411959
4A927A  SEDSZ https://www.planespotters.net/airframe/British-Aerospace/BAe-146/SE-DSZ-BRA-Braathens-Regional-Airlines/3xRrtZG
800C63  VTITZ https://xfw-spotter.blogspot.de/search/label/7892 (just in case...)
WZZ3XS W61904  EGGW EPPO (bnoticed due to broken packets received)
Regards Ingo
