0 Members and 26 Guests are viewing this topic.
Saturday:
3C0859  SDR6406 already posted within fridays unknowns
jacobite
Quote from: jacobite on November 18, 2017, 02:02:40 PM
Quote from: Runway 31 on November 18, 2017, 11:34:32 AM
Todays update gives me 257369 rows so it looks like your updates are going somewhere else.  You must have another instance somewhere on your computer so you will need to search for the correct one and move it into your working folder
I will trawl through my files and see if I have any other ANRB showing. I will let you know Alan.
Morning Alan, am I using the correct version of anrb? I am using 6.01.001 I could not find anything to conflict and cause the problem with updating the database.
AoD
new aircraft
49D3CD, Cessna 152, OK-LTC, 15281304, Aeroklub Praha Letňany
CarlosAbreu
Jacobite
I had that problem few months ago after resinstal ANRB automatically in My Programs folder. After that all updates were missing everytime I restart the application.
Backup you Airnav folder data and reinstal ANRB direct on C: and you'll get updates withou problems.
I hope it helps, solved my problem.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
jacobite
Quote from: CarlosAbreu on November 19, 2017, 12:20:24 PM
Jacobite
Carlos
Thanks Carlos I will give it a try.
X
This is 20th time I have picked 159944 up, this time it departed Ulyanovsk flew at 210kts at 18000ft and just landed VKO. Therefore a small prop aircraft is most likely eg Beech/PC12/Navajo sized type?? Could not see it as cloud cover is 800ft in MOW....I will get it one day!
   159944        2017/11/19 16:13:40
X
Morning Ingo
3C0859,D-ASEE,4953,Airbus A320-214,Sundair  SDR now the ICAO for Sundair, added on Friday
I cannot open the D-ELUR post as I am not a member, can you advise further info please
Mil tac added
48952E,SP-FKO,FR1720422,Reims FR172J Rocket
4A927A,SE-DSZ,E3380,British Aerospace AVRO 146-RJ100,Malmo Aviation added on departure from Cranfield
800C63,VT-ITZ,7892,Airbus A320-271N,IndiGo Airlines added on departure from XFW
Use Windows search to look for all instances of NavData.db3  it would appear that you have more than one instance on your computer and the software is reading the wrong one.  Use search to find the correct one which should be around 81,896KB in size with todays date and drag it into the data folder in use replacing the one that is already there.
If you installed into program files this may be the cause of your problem as the advice given is not to but to install to C;\Airnav or similar.  If you installed to program files and did a an auto uninstall orphan files are left behind including the Navdata and that would probably be the reason why you have more than one.
Afternoon Alan,
NLY2266 : EDDM-LEMG
TVS3400 : GCFV-LFLL
TVS3401 : LFLL-GCFV
CTN2401 : GMMX-LDZA
VLG6584 : LIRF-GCRR
VLG6585 : GCRR-LIRF
EZY91VE : LEAL-EGNT
JAF60A : LEAL-EBLG
Amendments :
c/n 22175/13 B757 G-BIKD DHL Air is wfu at Madrid.
c/n 30284/1233 B737 EC-III Air Europa is currently on lease to Eurowings.
c/n 17000121 EMB 170 HZ-AEE Saudi Arabian is in storage at Teruel.
Regarding D-ELUR I sent you a mail to your btinternet mail address.
jacobite
Quote from: jacobite on November 19, 2017, 12:45:02 PM
Jacobite
Carlos
No luck Carlos, thanks for trying to help. It looks like I will have to reinstall anrb that's if I can find it.
#12868
Thanks again Terry
Personally I only see a need for the c/n and don't see an need for a line number
Regarding Westland/AgustaWestland it all depend on the ownership of the company when the aircraft was built.  Should they now be Leanardo??
X unfortunately 159944 doesn't decode so without a flight ID there is little chance to tie it up
