0 Members and 31 Guests are viewing this topic.
#12885
This is the current one on the support page Ian http://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe  Although it states 6.01.02 it actually show 01 when loaded
Hi Terry,
I will stick to my d/b information and you can change it as you please.  For the Tornados the first number is the c/n, the second number is the line number what is the BS number?
Afternoon / evening Alan, Sundays unknowns:
39AE39  FHLRZ (2x) http://www.airport-data.com/aircraft/photo/001358280.html
MIL:
   3F61B7        2017/11/19 07:12:58
   3F61B7  GAF094                                                         2017/11/19 11:50:54
Regards Ingo
Evening Ian, thanks again
Evening Ingo
39AE39,F-HLRZ,50000165,Embraer EMB 500 Phenom 100,SDAviation,
Mil tac added
Didn't notice it is in twice as there is a miscode against it, its in now
Hi Ingo,
3D6875 D-FLUR has been in the d/b since June
#12894
yes I know. The first reception of correct reg/hex was on July 24th 2017. It auto populated at my 24/7 station without any problem.
Yesterday I received it with my mobile stick operated installtion here in Heidelberg. It didn't auto populated. The manual populate via MyLog didn't work either. That's I wanted the confirmation that it is still in the server db.
Many thanks!
Kenny
HS-BCO  (old hex A93B19)  has been rereg to 88086F which is wrongly assigned to HS-BC0 (bravo charlie zero) in the db.
CSZ9001  ZGSZ VTBS
CSZ9007  VTBS ZGGG
TBA6005  ZLXY VTSM
CCA805  ZSPD VTBS
CCA806  VTBS ZSPD
LKE801  ZPPP VTBS
LKE802  VTBS ZPPP
TLM039 ZGGG VTBD
Kenny
ANRB 3km north of VTBD
CarlosAbreu
20-11-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Mondays unknowns:
MILs:
* 3E9BE6  PACK41                                                         2017/11/20 18:04:05
* 3EACBE        2017/11/20 10:57:13
* 3F770D        2017/11/20 11:41:04
* 3F770D  BLADE2                                                         2017/11/20 15:32:09
TRA6902 HV6902 OMDB LBBG EHAM
Regarding D-FLUR: has populated today morning, must have been the internet connection.
Regards Ingo
M
EWG5599   ESNX   EDDS
BLX589   EFHK   GCRR
BLX590   GCRR   EFHK
TOM582   EFHK   GVAC
TOM583   GVAC   EFHK
Operators:
D-ISKO Peak Air
F-HALM Aero Vision
OY-FWO Blackbird Air
OY-SWO Blackbird Air
SE-MDC Danish Air Transport
VP-BCH Sky Gates Airlines
SP-KPV SprintAir
SP-KPE SprintAir
SP-KPN SprintAir Cargo
