0 Members and 44 Guests are viewing this topic.
Morning Ingo, thanks again
jacobite
Quote from: Runway 31 on November 20, 2017, 02:13:05 PM
This is the current one on the support page Ian http://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe  Although it states 6.01.02 it actually show 01 when loaded
Good morning Alan, I am having nightmares with setting up this download, it appears there is a corrupt data file in the software.
Morning Ian,
I am just downloading it to see whats what
I just downloaded and installed it OK Ian.  Where are you installing it to on your computer and at what point is the installation failing.
jacobite
Quote from: Runway 31 on November 21, 2017, 11:45:55 AM
It is not failing at the point of download, it's being installed c:\airnavsystems. I have never had this problem before, it has got me puzzled Alan. I just cannot update the routes database. I am sorry to be such a pain Alan it must be something on my laptop giving me the problem. Just as a thought, should I remove my micro radar box before I set anrb up.
#12907
I don't understand what you mean by a corrupt data file, if it was corrupt you wouldn't get anything.  Is the software running and the only problem you are having is the routes database is not updating?
When you update do you have all the Tables ticked and then use Update All Records
Thanks again Terry.  My d/b shows the 3 Hawks as with the Navy
jacobite
Quote from: Runway 31 on November 21, 2017, 02:03:22 PM
Yes Alan the software is running. The routes database is not updating, so I do not know what is causing the problem. Even when I input data manually when I check next day my inputs are not there.
It looks like you are still having the same problem as before in that the database is being downloaded to a previous installations data folder.  When you use Windows search and type in Navdata.db3 what does it show, there should only be one result is that the case
Afternoon Alan,
DLH1140 :EDDF-LEZL
DLH1141 : LEZL-EDDF
CFG1412 : EDDM-GCRR
EWG385 : GMMW-EDDK
Not populating : 345153 FL200 Flight id CASA968.
paul tricker
This passed overhead recently
500115 T7AMS
T7-AMS   PC12  732
Paul
ffa1978
Quote from: X on November 19, 2017, 01:57:05 PM
This is 20th time I have picked 159944 up, this time it departed Ulyanovsk flew at 210kts at 18000ft and just landed VKO. Therefore a small prop aircraft is most likely eg Beech/PC12/Navajo sized type?? Could not see it as cloud cover is 800ft in MOW....I will get it one day!
   159944        2017/11/19 16:13:40
X
Hi ! Im from Russia ,Ulyanovsk 159944 RA-26180 Antonov AN-26 Rocket space center "Progress" -Samara https://russianplanes.net/reginfo/6459
#12914
Afternoon Ian
No idea on your unknown but possibly a Kazak C295 on delivery as it is now over the heel of Italy
