0 Members and 24 Guests are viewing this topic.
Many thanks ffa1978, much appreciated
ffa1978
Quote from: Runway 31 on November 21, 2017, 03:49:10 PM
I can post link to my Basestation.sqb with unique HEX and Regs Russian and another aircraft for latest 5 years if need
Thanks for the offer ffa, contact me at [email protected]
While we have a decent database there will be always something we don't have as some of the aircraft from Russia don't always follow the recognised coding sequence such as 159944.
ffa1978
jacobite
Quote from: Runway 31 on November 21, 2017, 02:45:05 PM
It looks like you are still having the same problem as before in that the database is being downloaded to a previous installations data folder.  When you use Windows search and type in Navdata.db3 what does it show, there should only be one result is that the case
I get windows cannot find NavData.db3
#12921
I presume you have W10.  If so click on the Windows logo bottom left, you will see one line up Search Programs and Files in a box.  Click on the box and type Navdata.db3.  At the top of the Window that opens you will see all the Navdata.db3 files
It may be that you require to open up hidden files to see the NavData files.  Go to Control Panel/View and under advanced setting/Files and Folders tick Show hidden files, folders and drives
#12922
Terry,
I will need to make changes as the Hawks appear to have been entered unit number/ c/n instead of the other way around in the conventional manner,  All now changed
Michel
Alan,
ABW210 EHAM-UUDD
AFR38NR ESSA-LFPG
Michel
CarlosAbreu
21-11-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Tuesdays unknowns:
044058  S9800 no further information
MILs:
* 3EA0BC  RAVEN2                                                         2017/11/21 08:15:47
* 3EA0BC        2017/11/21 17:43:20
* 3EA14D  BU33                                                           2017/11/21 19:27:57
* 3EA188        2017/11/21 11:32:54
* 3F5B40  GAF807                                                         2017/11/21 09:12:11
* 3F5B40  GAF807                                                         2017/11/21 12:10:20
* 3F6E1A  BU31                                                           2017/11/21 19:21:07
459659  OYERY http://www.oy-reg.dk/register/2550.html
78114B  CSN166 B-8366 A333 on delivery from LFBO to ZGGG (already added I guess)
800C72  VTIVC https://xfw-spotter.blogspot.de/search/label/7931
800C77  GOW9111 https://xfw-spotter.blogspot.de/search/label/7859
both neos already added shortly after departure from EDHI I guess.
Regards Ingo
Morning Ingo,
044058,9G-SBF,743,Aerospatiale ATR 72-212A,Starbow Airlines out of Billund on delivery
459659,OY-ERY,550-0469,Cessna 550 Citation II,Jet Plane Corp
78114B,B-8366,1826,Airbus A330-343E,China Southern Airlines
800C72,VT-IVC,7931,Airbus A320-271N,IndiGo
800C77,VT-WGM,7859,Airbus A320-271N,GoAir
Mil tac added
jacobite
Quote from: Runway 31 on November 21, 2017, 06:45:01 PM
Alan, thanks for being so patient over my problem, I have tried looking every where and cannot find any NavData files.
my current aircraft count is 234519
routes count is 322005
You must have at least one Navdata.db3 Ian as you have a database and that is its file name and are getting a count.  If using search cannot find that one you wont be able to find any others.
Todays download should give 257516 aircraft and 364,529 routes
