1 Member and 38 Guests are viewing this topic.
Hi Terry,
I am away for the weekend and the updater software on the laptop I took with me doesn't work so I cannot do anything with these until I get back on Sunday afternoon.
However please note that the C-146 aircraft dont always show their military serial out of theatre and you will still find them as current on the FAA list i.e http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=545EF
CarlosAbreu
01-12-2017 Update file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Fridays unknowns:
3E386C  DIMOI http://www.laasdata.com/corpjet/corpjets-germany-icao-d.php According to eurocontrol export.xls: PROAIR AVIATION GMBH
750459  AXM9953 https://xfw-spotter.blogspot.de/search/label/6642 (Just in case)
Regards Ingo
ffa1978
424261 AFL1205 Regs ? Boeing ?
ffa1978
#13055
Not CP-2923 ! I seen this hex with callsign AFL1205 - Aeroflot -Russian Airlines !
#13056
Hi FFA
next time it would be great that you provide more details and name the oddity you found by name. Would save me much time investing in the wrong places or in the wrong direction.
look for Hex 424261
https://a320archive.com/?q=Delivered&type=flight-activity
https://a320archive.com/msn/7932
seems that it is still using wrong Hex. So at this time we have two airframes using same hex.
Edit: this one might not match either.
Edit2: I've checked Perm and Moscow time tables for SU1205. Results:
- Perm: Aircraft type / Manufacturer: Airbus
- Moscow: Aircraft type/ Manufacturer: Airbus Industrie A320
--> Good chance that it is indeed miscoded MSN7832 VP-BTO.
@Alan:
Alan, we have no chance to add this one to the db at the moment, as correct owner of hex 424261, reg: CP-2923, is a valid and very active aircraft too. We have to wait until aeroflott decides to change the hex of new VP-BTO. Previously a Airbus A319 using Reg VP-BTO: https://www.planespotters.net/airframe/Airbus/A319/5B-DCW-Cyprus-Airways-(2016)/EaoKs3E http://www.airfleets.net/ficheapp/plane-a319-1129.htm
CarlosAbreu
NLY2647 LPMA-EDDL operated by an aircraft with ICAO24 4400EF (not in database). In my search this code is from OE-GEJ an C560 from Jetalliance. It seems there's an error with the code, could you please check.
Carlos
Hi Terry,
I will look at them tomorrow when I get home.  For info they also use mil hex codes as well
Carlos
Thanks for the route info.  I am away for the weekend and will update it when I get home tomorrow
4400EF OE-LOD A320-214 c/n 3908 Niki
#13060
Ingo/ffa
I am away for the weekend and the updater software on this laptop is not working so cannot look into it until my return home tomorrow afternoon.
As far as I am aware VP-BTO has not been delivered yet https://xfw-spotter.blogspot.co.uk/search?q=vp-bto so I presume something else from the AFL fleet miscoding
The Bolivian as you are aware is miscoding its previous hex code so I my have to add the details in as various and in use by more than one aircraft if need be
Alan,
I visited xfw blog too. But fact is, that we have a flight from TLS to SVO with hex 424261 in RB24.COM flight history on nov 30th. Since then four further flights on dec 1st.
Thanks for that Ingo, can only presume that XFW Blogspot have missed the delivery.  Nothing noted on Skyliner either, very strange indeed.
Can you advise the flight ID for the delivery flight please and I will make enquiries as I have details of other deliveries out of TLS from yesterday to add into the d/b
CarlosAbreu
Thanks, I just added it manually to my database.
Have a nice weekend.
Carlos
CYYZGUY
WJA2756  No Routing
https://flightaware.com/live/flight/WJA2756
WJA2644 No Routing
https://flightaware.com/live/flight/WJA2644
WJA2598 No Routing
https://flightaware.com/live/flight/WJA2598
A sunwing plane missing some info....
C02258/SWG438
Missing Registration/Aircraft type/company
regards,
Jason
40" LED Monitor
40" LED Monitor
