0 Members and 27 Guests are viewing this topic.
Flight IDs:
SU7611 delivery
SU1102
SU1103
SU1204
SU1205
Hi Ingo/ffa
Had it confirmed 424261  VP-BTO  A320-214  c/n 7932  ex TLS 30 Nov as AFL7611.
So we have a true ID and the same miscode flying, great!!
#13067
Thanks Jason
Will catch up with them tomorrow
CO2558 C-FNAD B738 c/n 39093 ex OO-JAD on winters lease
ffa1978
Quote from: Runway 31 on December 02, 2017, 03:17:33 PM
Hi Ingo/ffa
Hi ! It's VP-BTO Names: N.Semashko
#13069
Thats whats on my post ffa
Ingo, the hex will not be changed as VP-BTO is the correct user of the code, the Bolivian is miscoding the same hex
ffa1978
About VP-BKK Aeroflot.Today change callsign to ABW5180 (AirBridgeCargo) and not transmitted coordinates.Why? Maybe the time will be AirBridgeCargo Airlines?
No idea ffa,  possibly a corruption somewhere as I cannot see ABW taking on passenger 738's
What shall we do now?
I would vote for: Add in the correct one and remove the miscoded one.
In AC we may add in: Aeroflot  (Miscode: 424261 CP-2923 of OB/BOV)
Problem of RB24.com and other websites will be that it is impossible to separate the two as we will farther get flight data from both aircraft.
FFA many thanks for pointing out this issue. As you may have noticed we have the problem, that we have two actively flying comercial aircraft with same HEX number of 424261. The one you have stated now and the one I falsely pointed to in my first reply.
The good thing Ingo is that we don,t have much in the way of coverage in Bolivia.  Will get it changed tomorrow on my return
#13074
Ja, a dubious advantage of RB24.com compared to FR24.com.
ffa1978
Quote from: Runway 31 on December 02, 2017, 04:31:48 PM
Not corruption .Not double hex for this
#13076
Correct its not a double hex but why would a newly delivered Aeroflot aircraft use an AirBridgeCargo flight ID??
Last flight I can see for VP-BKK was its delivery flight which arrived SVO late yesterday evening.  I cannot see any flights for it today so far.
FFA,
maybe you could be so kind to give us the source of your screenshots.
Is it data you received or is it a russian flight tracking website?
ABW is usually not using flight numbers with 4 digits after ABW.
Many thanks.
ffa1978
There are planes which have really hex,but periodically  gets off the transponder and begins to generate miscodehex .Example VP-BJL have two hex -424383 and bdbc7c (miscode)
ffa1978
Quote from: neroon79 on December 02, 2017, 05:12:20 PM
FFA,
Many thanks.
Its My friend russian ADSB site http://planeradar.ru/virtualradar/desktop.html#
