0 Members and 26 Guests are viewing this topic.
X
Atmospherics and high static conditions in MOW are really playing around so I am getting quite a few corrupt packages at the moment
For instance 489787 actually pinged as 4897B5 a few times with two letters/numerals out!
   489787  LOT676   UUEE-EPWA       SP-LDG     E170  LOT Polish Airlines  2017/12/03 15:44:15
* 4897B5        2017/12/03 15:56:51
I had this a lot in the sandpit with EK aircraft in certain weather conditions when aircraft were at distance, so I have generally learned to live with it!
X
X
#13111
Ingo/ffa
In the past I have asked operators to change their hexes when it was incorrect and in the case of a Bahrain based DHL 757 they actually did change it......would not know where to start in Russia! Maybe ffa knows somebody who could let them know VQ-BJX has two different codes in each box....at least he speaks the lingo!
X
ffa1978
#13112
X: In Russia it Impossible absolutly.I speak for change HEX to true permanetnly from inquiry phisical human(sorry for english).
About 1efa38 -I  know and seen this aircraft.Its RA-64056 T204 Tupolev Tu-204-100(В/Е) Aviastar-TU.Undergoing flight testing in my town. https://russianplanes.net/reginfo/82
Catching up
Thanks again Ian (EK01) for the information on Solarius Aviation as it is not detailed on the ICAO or FAA lists which 7 year later still detail TWY as the code for Sunset Aviation
Database amended to remove Sunset Aviation
Terry,
Wolfhounds all sorted
ffa1978
Alan:VQ-BQK S7 AIRLINES also have true and miscode hex.Note this
Thanks X/ffa regarding RA-64056.  For info my d/b gives it as c/n 64056 and was built using parts of 64153
ffa
I only have VQ-BBK with its correct code of 424571.  What miscode does it use please.
Carlos,
Your route info done
Ingo,
Your info added in
I think I am up to date with all posts now
ffa1978
Alan:VQ-BQK not VQ -BBK /Miscode for VQ-BQK 424171 -Confirmed
ffa1978
Quote from: Runway 31 on December 03, 2017, 04:59:29 PM
Not true.using parts of 64151
Ah yes I remember it now as 424171 was previously used by MD82 VP-VBH and noted regarding 54151
ffa1978
#13124
Quote from: Runway 31 on December 03, 2017, 05:41:48 PM
In database what i send your -all miscode contained with true regs
