0 Members and 15 Guests are viewing this topic.
ffa1978
Alan:I wanted to ask. In October I saw planes for 536 miles but on the site showed only 440 in statistic, at the same time constantly with European receivers 540+ showed .I many aircrafts seen for this period,but on site radarBox only for 440 мiles diagramm.Why? And so not once.My screenshot for 9 October
No idea ffa, maybe support could advise
CarlosAbreu
03-12-2017 Update file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
* AC404A  N889LM                                                         2017/12/03 22:08:41  627
Should be N889LM G650ER c/n 6276
X
X
Just to show you, these are all corrupt packages picked up at distance from 1800 last night that can be tied to another flight. This is much worse than usual so as stated earlier it must be current atmospheric conditions at play. That would be about 10 in total yesterday out of 2230 picked up so I can live with it!
* 424115        2017/12/03 18:46:33
    42494C        2017/12/03 22:12:56
    42494F        2017/12/03 18:04:03
X
Morning Terry, thanks again
Morning X
AC404A is N889LM and was added to the d/b last night
You can usually tell corrupt packets as they don't usually have any further info such as flight ID
M
CCA875   ZBAA   LFPG
FIN161   EFHK   VVTS
FIN162   VVTS   EFHK
FIN27   EFHK   MUHA
FIN28   MUHA   EFHK
TOM656   EFHK   MMUN
TOM657   MMUN   EFHK
APF2095   ESNU   ESMS
NTJ3PO   EFPO   ESSA
NTJU03   ESGJ   ESSA
FHY829   LCEN   ESSA   via LTAI
FHY830   ESSA   LCEN   via LTAI
BOX590   EDDP   VHHH   via RJAA
GTI511   KCVG   ZSPD   via ENGM
Operators:
OH-HBV Heliwest , cn:14078
D-BVHA Viessmann Werke
RA-02797 GT Energo
OY-RUG DOT LT
9H-JSY Elit'Avia Malta
X
#13135
Agreed not usually does one get flight ID with corrupt packages however in sandpit I was getting EK aircraft with airarabia c/s and vice versa which had me confused for a while! for example in 2013 here is UAE/EK309 from Beijing China showing as A6-ABU and A6-ANI as flyDubai from Beirut
89632C  UAE309   ZBAA-OMDB       A6-ABU  A320  Air Arabia           2013/05/07 11:53:50
89633B  FDB156   OLBA-OMDB       A6-ANI  A320  Air Arabia           2013/05/07 07:28:48
X
#13136
Morning Alan,
JAF7224 : LEAL-EBAW
ENT575A : LPFR-EPWA
TVF85MZ : LFLL-GMFO
SWR5101 : LEMG-LSZH
JAF95B : LELC-EBAW
JAF25H : EBLG-LEAL
RAM650 : GMFO-LFPO
AFR536A : LFPG-DFFD
ELY018 : KMIA-LLBG
EI-FXM A319 c/n 2382 of Volotea has been reregistered as EC-MTF. Not sure if a new hex has been issued but it is currently in service as EC-MTF.
Unfortunately you will get that with corrupt packets when the software recognises the duff hex and the details from the database but no idea why it would then tie on the flight ID unless that was also flying at the time and added the flight ID it was using
