0 Members and 29 Guests are viewing this topic.
X
#13155
PS Only two corrupt packets out of 2200 today so atmospheric conditions are obviously more normal than that of yesterday.
X
Yes that's correct X.  Unfortunately my box died and I had to go onto a dongle therefore I am stuck with V6
X
Also you were correct on my Sandpit issue...on looking back all noted aircraft were in flight within range when I got the crossed code issue/f/n issue in 2013. but I believe we discussed that back then and put it down to adverse atmospheric conditions in the Gulf region when at range (250nm)
X
CarlosAbreu
04-12-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Terry, many thanks
Kenny
VGO5211  VTUQ  VTCC
VGO5212  VTCC  VTUQ
VGO7221  VTUQ  VTSP
VGO7222  VTSP   VTUQ
BKP167  VTBS  VTSM
ANRB 3km north of VTBD
Evening Alan, Mondays unknowns:
03F66D  SHOCK22 (miscoded MIL I presume)
105C07  SSG004
MILs:
* 3F6A38  GAF601                                                         2017/12/04 09:35:16
* 3F6A38  GAF601                                                         2017/12/04 14:50:08
   3F786A  SPARK                                                          2017/12/04 08:07:11
   3F786A        2017/12/04 08:58:45
   3F786A        2017/12/04 13:18:27
800C70  VTIVA https://xfw-spotter.blogspot.de/search/label/7912 already added I guess
Regards Ingo
Evening Ingo
800C70,VT-IVA,7912,Airbus A320-271N,IndiGo,
03F66D  SHOCK22 presumably miscoded German mil tac code??
105C07  SSG004 unknown to me
Mil tac added
Evening Terry, thanks again
X
#13166
   1F1D5B                           73051      ZZZZ  Irkut Corporation    2017/12/05 11:37:22
   1F1D5B                           73051      ZZZZ  Irkut Corporation    2017/12/05 12:29:02
   1F1D5B                           73051      ZZZZ  Irkut Corporation    2017/12/05 13:37:47
Assume no ICAO code for an Irkut MC21 as yet:)
No miscodes at all today out of 2200 reports so atmospherics must be OK today!!
Will probably be back in Blighty next week if so will contact you
X
Nope no ICAO for it yet X
I will be in Spain Tuesday till Friday next week but OK after that
X
AN148 or AN48?
    14F120                               RA-61728   A148  Russia - Air Force   2017/12/05 16:55:56
* 14F123  61731                    RA-61731   AN48  Russia - Air Force   2017/12/05 17:17:27
That's a quick visit for you...assume you are flying! see you when you are back
X
