0 Members and 35 Guests are viewing this topic.
Good Afternoon/Evening Alan, Tuesdays unknowns:
03F66D VADER23 I suspect a miscoded MIL aircraft
MILs:
* 3E995B  DIXI07                                                         2017/12/05 14:40:45
   3E9EFF        2017/12/05 09:19:34
   3F786A        2017/12/05 13:21:17
* 3FB558  HG01A                                                          2017/12/05 15:14:08
* 3FB8E4  GAF688                                                         2017/12/05 15:56:11
500110  T7HHL (Bad packet or miscoded)
500114  T7HHL
H25B EMPIRE AVIATION SAN MARINO SRL
888141  VJC7953 https://xfw-spotter.blogspot.de/search/label/7953 (Already added I guess)
Regards Ingo
Afternoon Alan,
THY3441 : LPPR-LTBA
THY3342 : LPPR-LTBA  (Note the similarity in flight id's. The first is the am flight and the second the pm flight).
JAF8AH : EBAW-LELC
EVE1131 : LEBL-LEGR
EVE1132 : LEGR-LEBL  (Flight being operated by B737 EC-LVR of Air Europa).
ANE36WA : LEVC-LEIB
3E9028 GAF098 not populating but presumably a tactical code.
My error X 4D0297 is LX-SIX.  I corrupted the hex 4D0287 for LX-HMD when I added it in the other day
Evening Ingo
888141,VN-A644,7953,Airbus A321-211,VietJetAir
03F66D is presumed to be German mil, mil tac added
I have nothing on T7-HHL, do you have anything further on it.  It is 500114
Evening Ian, Thanks for those
jacobite
Quote from: Runway 31 on December 06, 2017, 03:35:55 PM
Yes, you should have 258,*** in the aircraft table and 365,*** .  Where did you install V6 too on your computer as what you have comes with the download.  Can you also go into program files and program files )x86) and see if there are any Airnav folders in there.
Having just looked I have program files(x86) ANRB60002 Setup I do not have any other airnav files.Would you sugest that I uninstall ?
Regarding T7-HHL:
The only info I found is from the export.xls of eurocontrol. I wasn't able to find any other information about T7-HHL except the details I gave with my todays post.
Terry,
Regarding 44F828 mil mode-s gives it as AT-22 and confirmed.  However I not the sequence and as you state AT-18 would fit it but I know that logic does not always dictate with hex codes.  How did ADSB exchange acquire the tie up??
Uninstall through Control Panel.  Then go into program files and delete manually everything left behind.  After that install to c:\Airnav
jacobite
Quote from: Runway 31 on December 06, 2017, 06:45:23 PM
Alan I have now got Aircraft 258257
and routes 365097
Please Alan say that it is correct
Yes that looks ok, well done that man
CarlosAbreu
06-12-2017 Update file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
jacobite
Quote from: Runway 31 on December 06, 2017, 09:14:46 PM
Well done you, many thanks for your help Alan.
