0 Members and 66 Guests are viewing this topic.
Hi Niklas,
I cannot get on the server just now to check, some of them are definitely in from your log though.
M
CFG6LA   EDDM   ENEV   via ENTC
CFG6KL   ENEV   EDDM
NTJ1005   ESGJ   ESSA
FIN4QJ   ESSV   EFHK
FIN769   EFHK   LOWW
FIN770   LOWW   EFHK
SAS7993   ESSA   LTAI
SAS7994   LTAI   ESSA
BGH5047   LBBG   ENVA
BGH5048   ENVA   LBBG
NAX1076   ENBR   EVRA
NAX1077   EVRA   ENBR
47859D / LN-MTP / C172 / Cessna 172P Skyhawk / Vaernes Flyklubb / 172-75197
461C56 / OH-KTA / DV20 / HOAC DV 20 Katana / Turun Lentokerho / 20063
Miscodes (neither of these two german hexes are currently included in the database).
3D392A / OH-TEE / XA42 / XtremeAir XA42 / Private / 113 / (allocated 463298)
3FEAED / OH-U589 / C42 / Ikarus C42 B / Private / 0611-6857 / (allocated 464A7D)
X
For a change...
FDB8847 OMDB-OERK  A6-FEJ     B738  flydubai             2015/06/26 22:43:11
FDB8848 OERK-OMDB  A6-FEJ     B738  flydubai             2015/06/27
X
X
FDB675 OMDB-HTZA-HTDA
No sign of the return leg yet (FDB676?)
FDB877 OMDB-OETF  A6-FDO     B738  flydubai             2015/06/27
FDB878 OETF-OMDB  A6-FDO     B738  flydubai             2015/06/27
X
jim_stockwell
Hi Alan
Not populating is hex 4B197A AT 40K ft. Sorry no other info
Jim
orkney
Hello M, X and Jim
That is them all done apart from Jim's Swiss one as I cannot find anything for it.
Many Thanks
Andrew
Kenny
* 881BA5        2015/06/24 10:47:38
* 885179  THA8935                                                        2015/06/24 18:24:46
* 8A0447  PKTFS                                                          2015/06/24 22:24:51
885179  HS-TKY  B77W  Boeing 777-3D7(ER)  cn 42114 / 1310  op Thai Airways International
LKE9639  ZPPP  VTSG
LKE9640  VTSG  ZPPP
KND9213  VTBD  VTPM
KND9215  VTBD  VTPM
KND9216  VTPM  VTBD
Kenny
ANRB 3km north of VTBD
flygfantast
#1327
Alan/Andrew
222222 is in the d/b as YR-VIS, ith should be changed into VARIOUS (Broken/miscoded transponder) as it's also used by SE-XNC.
478736 LN-AKC, Vans RV7, c/n 72397, Frog Alf Olav Horne
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Kenny
They are all in apart from 881BA5 which I cannot find details for.
Many thanks
Andrew
orkney
Hello Niklas
That is that one changed and the other one added.
Thanks Again
Andrew
X
Just had 702059 OTT and it was seen as a B777 but it showed as S2-AGW DH8D and at 36000ft...highly unlikely, should be S2-AHK B777. I believe S2-AGW should be 702065.
X
orkney
Hello X
That is that two sorted out now.
Thanks once again
Andrew
CYYZGUY
40" LED Monitor
40" LED Monitor
flygfantast
Andrew
80073C VT-ANV, Boeing B787-8 Dreamliner, c/n 36293/311, Air India
Niklas
X
#1334
Hi Andrew
Thanks I do not know what happened but S2-AHK is a regular OTT and was correct as a B777 until very recently, that was first time it came up as S2-AGW DH8D!
also unknown miscode in the area, but only 2 pings so probably spurious but is third time this year.
4E540A        2015/06/27 22:42:23
X
