0 Members and 46 Guests are viewing this topic.
Hi Andrew/Niklas
71C076 c/s KAL904D is A333 HL8076 on delivery out of TLS 24/6
CYYZGUY
40" LED Monitor
40" LED Monitor
54901 - Jim
Here's one for you, Alan ...
AC6C2C / N9TJ / GLEX / Bombardier Aerospace Corp / 9659
Thanks!
Jim
KOSH - Oshkosh, Wisconsin USA
Michel
#1355
Alan,
CND617 EHAM-HEGN iso EHAM-DTNH
TRA203 EHAM-LTBS iso EHRD-LPFR
TRA1883 EHAM-LGKL
CAI708 EHAM-LTFG iso EHAM-LTFE
KKK5MA EHAM-LTBA (I think you can delete KKK6OU EHAM-LTBA)
UAL976 KIAD-OMDB iso KIAD-OMDB-OTHH
Michel
Morning Alan,
Missing route details from over the weekend. Some may just require recycling :
SAS1854: LEAL-ESSA
VLG1354 : LEAL-LEIB
SAS4674 : LEAL-ENGM
VLG7888 : LEBL-GOOY
ETH713 : LEMD-LIRF-HAAB
AZA8269 : LEAM-LIRF operated by YR-BAS c/n 27007 of Blue Air.
VLG2459 : LEMH-LEMG
VLG4750 : LIRF-LPPT
VLG1366 : LEAL-LIRF
NAX5419 : LMML-LEMD
AFR1555 : DAAG-LFPG
THY2YB : LEMG-LTBA
There was also BMR9472 came into LEAL on Sunday evening but I was unable to obtain any route info.
falcon_nl
New one:
448DF2, OO-COR, C182, Reims F182Q, 18200129
Thanks again falcon, already got it.
Good Afternoon, unknowns from Monday:
12BFCF nothing more
3C4871  BER251X http://www.flightradar24.com/data/airplanes/d-abcq/ delivery XFW TXL
3D14A0 D-EGBG http://planefinder.net/data/aircraft/D-EGBG
3D1C7B  DEJAP http://planefinder.net/data/aircraft/D-EJAP
3D253F  DEMIX no further information
3D2563  DEMKL received two times that day, https://www.flickr.com/photos/70866411@N05/sets/72157635003193678/
3F00E1  D8266 http://www.vfs-krefeld.de/index.php?option=com_content&view=article&id=62:d-8266&catid=34&Itemid=112
3FF3B1  DMIBE no further information
49C107  OKNHA35 posted yesterday (I hope it will populate later...)
4B12CE nothing more
502C6C http://www.flightradar24.com/data/airplanes/yl-and/ and airframes
510540 no country allocation
MILs:
* 3E8892        2015/06/29 07:13:50
* 3E8892        2015/06/29 08:27:55
* 3E9F82  GAF640                                                         2015/06/29 11:17:18
* 3EB4A1  MIG                                                            2015/06/29 08:48:23
    3F4633  GAFM51A                                                        2015/06/29 09:07:48
* 3F4B3A  METAL2                                                         2015/06/29 09:24:20
* 3F55A4  MONSTR                                                         2015/06/29 07:49:32
   3F5877  LM02                                                           2015/06/29 06:10:12
   3F5877  LM02                                                           2015/06/29 10:12:41
* 3F84A7  THOR1                                                          2015/06/29 08:34:56
Greetings from cloudless 30°C warm Heidelberg!
Regards Ingo
Hi Ingo,
3C4871  BER251X D-ABCQ added yesterday evening
3D14A0,D-EBGB,F17200979,Reims F172M Skyhawk
3D1C7B,D-EJAP,T18208725,Cessna T182T Skylane
3D253F D-EMIX, can find no details of any current frame
3D2563 D-EMKL decodes to 3D2567 and is in the d/b as such so miscoding.
3F00E1,D-8266,17,Schempp-Hirth Discus 2B
49C107  OKNHA35 added to the d/b yesterday by Andrew
502C6C,YL-AND,172S10633,Cessna 172S Skyhawk SP
Nothing on the others and mil tac added.
Many thanks
Evening Alan,
D/B update for you. Swiss European Air Lines have changed their name to Swiss Global Air Lines. Swiss International Air Lines remain unchanged.
flygfantast
#1363
Todays unknowns/non populating:
12BF59 no c/s (Russia)
00C6F6 no c/s (South Africa)
3F5F58 GAF601 Tactical
Also from yesterday: 3E964A GAF703 Tactical
Route update (taken from received ACARS messages):
WZZ1042 ESKN-EPGD
WZZ25S EPGD-ESKN
WZZ24D ENZV-EPGD
Niklas
Cable: Ecoflex-10 (10m+1m)
Many thanks Niklas,
Mil tac added but can find nothing on the others.
I have added in the routes but tomorrow is the 1st of the month and WZZ are liable to change their flight ID,s
