0 Members and 52 Guests are viewing this topic.
Thanks again falcon
440810 OE-LED A320 c/n 4606 ex D-ABFP
CYYZGUY
#1383
Goodmorning Alan, a flight with missing info.
Mode-S C07CF9
Flight ID CGVIM
Also..
C18749...only mode-S
thats all.
regards,
Jason
40" LED Monitor
40" LED Monitor
CYYZGUY
40" LED Monitor
40" LED Monitor
falcon_nl
Quote from: Runway 31 on June 05, 2015, 01:44:48 PM
Ingo,
13th May
3FF36A D-MYCH unknown to me
ATC contact with D-MYCH (calling himself D-MWCH with a Stout HF airplane ?)
checked it with the Squawk 3704.
Audiofile: http://s000.tinyupload.com/index.php?file_id=32085737847713043756
#1386
Hi Jason,
C07CF9,C-GVIM,1012,Pilatus PC-12/47E,Private Air
No idea on C18749
Thanks for the routes
I have nothing on D-MWCH either.
Blueboy
Hi Alan, picking-up hex 48509D which I believe is DASH-8D P4-NUR  c/n 4494
J.D
Afternoon alan, unknowns from Tuesday:
000024  BS100024 no country allocation
0003C3 two times, but same as above
3836AB F-BNVL http://www.amcarusa.com/aa8800/hh9kjjk/various/var094COR.htm
3D1C7B  DEJAP http://planefinder.net/data/aircraft/D-EJAP
3FF0F3  DMYPI no further information
3FF2D6  DMMSE still no luck with the details
3FF33B  DMHCB same as above
3FF341  DMKLY no further information
4407F7  OEIIH no further information
440C8F nothing more
4690FA  AEE9E http://www.flightradar24.com/data/airplanes/sx-dgz/
49C107  OKNHA35 populate function definitely not working as it should. It takes more than 30min to ran a cycle of 300 items. Usually this takes about 10mins.
4BA9EA  THY6902 http://www.flightradar24.com/data/airplanes/tc-joj/ I guess this was already added, but hasn't populated for the known  reason
7803BF  CES9001 http://www.flightradar24.com/data/airplanes/b-5975/
780D8A http://www.flightradar24.com/data/airplanes/b-1638/
7C58F7 nothing more
8962E9  A6PFA http://www.airfleets.net/ficheapp/plane-b747-37500.htm
MILs:
* 3E8EA1  KNIGHT2                                                        2015/06/30 14:14:41
   3F451B        2015/06/30 13:17:46
   3F4B3A        2015/06/30 08:48:23
* 3F50C3  CONAN1                                                         2015/06/30 08:43:15
   3F55A4  MONSTR                                                         2015/06/30 09:09:59
   3F5877  LM02                                                           2015/06/30 08:14:27
* 3F5CE2  DRAGON                                                         2015/06/30 08:12:59
* 3F5CE2  DRAGON                                                         2015/06/30 10:02:46
* 3F6C28  GAF626                                                         2015/06/30 14:29:21
* 3F6C28  GAF777                                                         2015/06/30 18:26:47
   3F7DBB        2015/06/30 12:50:59
* 3F9E76  GAF640                                                         2015/06/30 11:26:57
* 3F9E76  GAF640                                                         2015/06/30 13:40:13
* 3FB17F  GAF712                                                         2015/06/30 10:18:50
* 3FBB25  GAF120                                                         2015/06/30 11:03:04
* 3FBB25  GAF120                                                         2015/06/30 13:38:00
Grettings from 33°C warm and cloudless Heidelberg
Regards Ingo
CYYZGUY
And another unknown
Only Mode-S
AD84EA
regards,
Jason
40" LED Monitor
40" LED Monitor
jim_stockwell
Hi Alan
3 non populating from today
3B7642 probably a French military helicopter with a message count of 42
66016c with a message count of 2
and 440809 with a flight i/d of OE-IVG
JIM
Hi JD,
It is and is in the d/b, added yesterday when it left the factory.
jim_stockwell
Yet another not populating was 48509D. sorry no other info shown
Jim
Afternoon Alan,
AAF441 : LFPO-DAON
ENT5353 : EPKT-LEAL
ENT5354 : LEAL-EPKT
BEL3774 : LEAL-EBBR
BEL3773 : EBBR-LEAL
