0 Members and 95 Guests are viewing this topic.
Thanks Ingo, both in the d/b
Evening Terry, thanks again
ffa1978
X
ffa
1F1D1B is unlikely to be a helicopter as it got to 20,000ft and 300+ knots, it was in an area 50-100km SE of MOW doing flight tests and did overshoots at ZIA.
c/s changed three times in flight first U, then P P and finally CJP.
X
X
I know 100000 is not much use being a hex miscode but tied it up from its c/s
  100000  RA2547G                                                        2018/01/25 06:18:26
RA-2547G is a Zlin Z-43....early riser for a bit of tin!
X
ffa1978
#13730
Quote from: X on January 25, 2018, 07:46:37 AM
ffa
X
as it got to 20,000ft and 300+ knots. Hi !From friend  vrs radar .Start flight from Zukovskiy MO Speed 313 to 231 km/h .Altitude 198 meters !! its helicopter imho
ffa1978
About 100000 hex -it's ra-2547G and RA-46395 and RF-31360
Hex 100000 also being used at this time by an OE-H*** helicopter so a miscode in use by a large number of aircraft
X
#13733
ffa
This is from info I have
ZIA MOSCOW
MSK (UTC +03:00)
DEPARTURE
SCHEDULED -
ACTUAL 11:50
N/A
ARRIVAL
SCHEDULED -
ESTIMATED -
________________________________________
TYPE
N/A
REGISTRATION
N/A
MODE-S CODE
1F1D1B
SERIAL NUMBER (MSN)
N/A
AGE
N/A
CALIBRATED ALTITUDE
18,925 ft
VERTICAL SPEED
-2,048 fpm
GPS ALTITUDE
TRACK
89°
Speed & altitude graph
SPEED
ALTITUDE
GROUND SPEED
272 kts
It increased altitude and speed after this and flew in circles for a long period with an overshoot of ZIA at 140-160 knots. Whatever it is we have a mystery flying object.
X
ffa1978
My post with real speed and altitude from local vrs
X
#13735
ffa
Well whatever it is we need to find out what it is. Hope you or friends can help out. I see the MC23 73051 is up again today at ZIA as c/s PU2MHA0 doing more or less the same as our mystery one did yesterday!
X
ffa1978
6010C5 ? May be Kyrgystan Air Force (il76?).Voice callsign Rassolnik 4283 :)
Afternoon Terry, thanks again
I don't have any information on that one ffa
Good afternoon/evening Alan, Wednesdays unknowns:
MILs:
   3CDB26        2018/01/24 17:31:25
* 3EB1A1  PUMA                                                           2018/01/24 13:42:58
* 3F5FF2  PACK71                                                         2018/01/24 19:12:34
* 3F6990  DASA07                                                         2018/01/24 16:54:56
888156  VJC8076 https://xfw-spotter.blogspot.de/2018/01/a321-211sl-vietjet-air-d-avyt-vn-a648.html (JIC post)
Regards Ingo
