0 Members and 15 Guests are viewing this topic.
Afternoon Ian
VH-CCV has been in the database for a couple of years, its the one that has taken on the hex code of its previous ID 4D020E which is unknown
Hi Terry
Yes and I was only stating the details on the companies website
Morning Ingo
3FF5B3,D-MEAV,,TL Ultralight TL-2000 Sting S4,
44010B,OE-DAM,46-8608030,Piper PA-46-310P Malibu,Andreas Mauhart,
Thanks again Terry
When did you pick up 9H-SOL, it must be newly registered as it isn't on the Maltese register of 15/2
Morning Alan,
VLG137C : LEAL-EHAM  I think I gave you this before but it doesn't appear to have gone through.
LLP83VB : GCTS-EPKT
Not populating : 39810B
Flight id F-HAIL at 420 feet
Morning Ian
No idea if you gave me it previously but its in now
39810B decodes as you state to F-HAIL.  Nothing current on the French register, the previous holder was an EC35 which became HB-ZAJ and then 3A-MCR before coming of the Monaco register as the registration has now been taken over by an EC20.  No idea what it is now
Thanks Alan.
I'll keep a lookout to see if it comes over. It does sound though as if it may be a helicopter of some kind as it was picked up at 420ft and currently is still on (non ADSB) at 645ft but nothing heard.
Ian,
You must untick the box Radie as that give historical information
Thanks Terry, CH Aviation states future so it must be due soon especially if they have applied for RVSM for it
Alan,
Silly me. I should have known that you were fluent in French. It timed out on the ground at 95ft so is either close by or at Ibiza where I can pick up aircraft on the ground.
Incidentally, FYI EC-MSZ Air Europa B787-9 has been on AEA7879 given as LEMD-LEPA. It must be a proving flight as it is not long delivered and I have not known a B787 to be used on this particular route.
Hi Ian,
At 95ft I think you are needing to get your super new binoculars into action
Yes it noticed it, probably just giving it a wee run carrying out snagging looking for any defects  and getting the crew used to it etc
