0 Members and 17 Guests are viewing this topic.
They are at Lasham for Jet2, neither been registered yet though
paul tricker
Unknown today
* 4850C9  BFY426R                                                        2018/02/23 12:42:07
Global P4-BFK is due into Stansted with this callsign, but I cannot find a c/n
Paul
paul tricker
Paul/Ian
4850C9,P4-BFK,9098,Bombardier BD-700-1A10 Global Express,Bestfly ex CS-DVE
Afternoon Alan,
VLG137C : LEAL-EHAM
And not sure if they have been changed yet, but just to stop you from becoming bored, all Virgin America aircraft were officially registered to Alaska Airlines on the 11th January 2018.
#14046
Thankfully it only took seconds to change the 67 aircraft involved Ian
Been making a number of changes to the VLG flight ID's noted over the last few days
For info, there has been a number of urgent tasks for the developers to undertake this week and they have not had the time to correct the database issue yet but its pencilled in for Monday morning
Vueling are just a complete nightmare with their flight id's !
Carlos
Can you find out anything about 4956A4 CS-UUD please
Many thanks
Thanks Terry
I wish these companies would decide what these want to call themselves.  One of these was only entered a few days ago from the information you gave previously.
As far as I am concerned Terry, the Belgian registered aircraft are Air Service Liege and the Dutch registered ones are JetNetherlands.  All the Belgian registered ones are registered to Air Services Liege.  As the companies are so tightly together I would imagine they will use aircraft from the combined fleet as required
phil zech
I updated database this morning and total number of aircraft has jumped from approx 260000 to 440000. Is there sonething wrong here or has someone been very busy !  Many thanks Regards   Phil
Phil
Airnav have added in aircraft on the FAA list using a recent FAA update as the basis,  Only hex, registration and c/n have been added.  I have no problems with that at all and I was advised that existing records would not be touched.  However there has been an impact on existing records as the c/n - line number of existing Boings has been changed to c/n only also the format for others has been changed to the format in the FAA list which is not always correct.
The process also added back into the database aircraft that had been deleted due to them be re-registered since the date of the FAA update therefore there are now aircraft frames which are duplicated so you may see the same c/n number used twice.
All this has been explained since the process was noted last weekend and users were advised to refrain from updating their Navadata databases until the database was repaired however doing so will not have a big impact if you are happy to live with these errors.
I have been advised that corrective action is pencilled in for this coming Monday and will advise when done
#14054
Afternoon Alan,
A couple of non populators:
E493E5 FL250 Full ADSB flight id AZU9841.
345694 Flight id: ECXQIZZZ (yeh right).
SVR3356 : LEMG-URKK
SVR3355 : URKK-LEMG
