0 Members and 23 Guests are viewing this topic.
CarlosAbreu
Could you please clarify the folowing situation:
On my task manager ANRB application appears as 32 bits. however I donwloaded last version available from Airnav Systems site (6.01.001) with same procedure for drivers.
My system is Windows 10 Professional 64 bits.
Could this have any interference with decoded data in antenna range ?
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
CarlosAbreu
12-03-2018 Updated file in attach.
Carlos
Carlos,
I'm running V6.01.001 on WIN10 professional too and I havent't noticed any interference with data decoding.
Ages ago I migrated from WIN XP 32bit to WIN7 64 bit without any significant change in range, received message rate or aircraft count per day.
I do notice a change if I use a DVB-T Stick (SDR) instead of classic hardware. More messages, more range, more AC per day less decoding errors if I'm using a stick.
Good morning Alan, Mondays unknown MIL:
* 3F8592  GAF822                                                         2018/03/12 08:41:09
* 3F8592  GAF822                                                         2018/03/12 13:24:42
* 3F8592  GAF822                                                         2018/03/12 14:13:35
Regards Ingo
#14240
Hi Carlos,
The driver pack contains both 32 bit and 64 bit drivers and will have no impact on range.  I use 64 bit and don't have any range issues, also the software and driver pack has not changed for a couple of years before you started to have range issues
Could I suggest that you take your receiver(s) elsewhere and compare the range if you have access to a laptop.  Even with the small antenna that comes with the receiver you should get over 200 miles range.  If you don't get decent range it would point to problems with your box if the range is good it would point to your antenna set up
Thanks for the route information
Ingo for your information Carlos is experiencing range issues having once had good range it is now very short.
Morning Ingo
That tac code was added in yesterday probably during the second of your received flights
X
* 141CCC  RA07372                                                        2018/03/13 09:12:06
Should be RA-07372 Robinson R66 Turbine c/n 0831
X
It is X
141CCC,RA-07372,0831,Robinson R66 Turbine
X
Unknown Liberian in the MOW area
* 05009E        2018/03/13 11:50:37
X
X
This is the An-26 that crashed last week, do not know if it was in db
RF-92955/52 red   26B   101 07   W/O nr Latakia Khmeimim AB Syria 6/3/18 opb VVS
X
X
#14246
Alan/ffa
RA-09005 unknown noted yesterday has just returned from Sochi/Adler to SVO. Still no clue as to type but assume we have a new biz (Falcon?) jet locally.
X
X
No idea on 05009E but I would wager it is nothing to do with Liberia
Didn't have RA-92955 is the d/b
RA-09005 has been asked about on mode-s but no answers yet
Evening Terry
For VALLJET I have went with the company themselves and they have the name all in capitals http://www.valljet.com/?lang=en
X
#14249
We appear to have another reg reuse, it was a B752 but what is using it now? Seems to have come from Istanbul SAW to DME
* 424439  VQBAL                                                          2018/03/13 22:04:33
X
