0 Members and 14 Guests are viewing this topic.
Morning Ingo
Mil tac added
C07C2D,C-GVAQ,960,Viking Air DHC-6-400 Twin Otter,Viking Air caught yesterday and presumably on delivery
Nothing on your other two
Afternoon Alan,
Not populating :
3E62BF Flight id shown as D-KCPB
Afternoon Terry
The Izmir Airlines aircraft all operate only on PGT flights since 2014 hence the PGT flight ID.  Planespotters have the leasee hidden but Airfleets show such as http://www.airfleets.net/ficheapp/plane-b737ng-34904.htm
Afternoon Ian
3E62BF,D-KCPB,15/442,Schempp-Hirth Ventus cM
Evening Terry, thanks again
superspotter
Greetings from Athens, for a change;
Hexcode 468013 is a Greek Air Force T-6A Texan, dont know if these change the hex every day like those pesky Germans?!
regards clive.
superspotter
Let me try again, with the reg this time!!
Hexcode 468013 is 019, a Greek Air Force T-6A Texan, dont know if these change the hex every day like those pesky Germans?!
regards clive.
Hi Clive
Can you confirm visual ID as I have it as an F-16.  Both types have the same serial.  I thought that originally via my d/b but mil mode S shows it to be an F16.  Then scrolled my d/b and found the F16 with same serial
superspotter
No, I didnt eyeball it Alan so have to scrap that one then, regards clive.
Clive
In that case it should be 468013,019,WJ-19,General Dynamic F-16C Fighting Falcon,Greece - Air Force
There is an F-16 base a little north of Athens.  The T-6's are based a good bit away
Afternoon Alan,
Have AN changed their log in screen. It used to save my password and all I had to do was put in my user name but now it requires my password to be put in each time as well before I can log in ?
Nope I haven't had that just clicked on as normal.  Have you unticked remember my password or the like or cleared your intenet history?
Afternoon Alan, Thursdays unknowns:
3DD4BD  DHAUV D-HAUV(2) Aerospatiale 350B2 Ecureuil > Aerospatiale-Soloy 350B2 "SD2" (2371), Meravo Luftreederei GmbH, Oedheim Heliport, [ex D-HENN, D-HFSB, (CS-HFS), D-HFSB], 20/06/2017, 16/02/2017P. http://www.helionline.net/templates/sites/ama_azz.html
MILs:
* 3E87D0  PANTER1                                                        2018/03/15 09:09:46
* 3E92B8        2018/03/15 14:19:26
* 3F5D52  POISON1                                                        2018/03/15 18:28:18
* 3F8935  HELI131                                                        2018/03/15 08:47:54
* 3F8935  HELI131                                                        2018/03/15 13:14:07
no details about the presumed heli...
7812C2  CQH1023 https://xfw-spotter.blogspot.de/2018/01/a320-214sl-spring-airlines-d-axak-b.html (just in case)
Regards Ingo
Alan,
I have a feeling I may have cleared my internet history. Where do I go to tick/untick to prevent it continually happening. In simple language please, you know what I am like with regard to pressing buttons that perhaps shouldn't be pressed !
