0 Members and 64 Guests are viewing this topic.
Hi AoD
503DBD,LY-NVY,1909,Airbus A320-214,Avion Express/Condor
3D29DE,D-EOCK,3546,Cirrus SR22,
3E291C decodes to D-IGTO unknown to me
2C011C miscode unknown to me
4CAA3A unknown to me
38C95C,59DNF,151,Aveko VL-3 Sprint,(radio call sign F-JZTE),
150408  decodes to RA-66568 unknown to me
505CE4 unknown to me
3D1C25,D-EIXH,2890191,Piper PA-28-181 Archer II
Many thanks
CarlosAbreu
27-05-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
#15107
Good morning Alan, Sundays unknowns:
3D49DE  DFAFM (2x) received again
3E5F53  DKBHJ (2x) http://www.airliners.net/photo/Untitled/Valentin-Taifun-17E/4197969?qsp=eJwtjbEKwkAQRP9lay1EsEiXYCFaaOEPLHtDPDhzx%2B4GDCH/7nnYDW8eMytJnhwffy4F1JGBVV60o8LKb6NuJcUYzZU95qkXnzlV77y/DZdr9SyrD0slgR29CIoj/PldA/RXwaRNjvXiUAP00TIdT5WHaCVx24BzTLRtX0rHMig%3D
3FF50F  DMBPR Zenair Zodiac https://www.planelogger.com/Airport/View/SHM
3FF655  DMMZF reception was shortly after you have added it. Plus, every single aircraft that was added on Thursday/Friday and was received again on Saturday hadn't autopopulated either. It seems, that there might be some kind of issue with the autopopulate. Furthermore the manual populate cycles are needing an awful amount of time to complete. Maybe airnav should check the server if there is a problem on their end.
3FF66D  DMVLW no further information
3FF680  DMAXF still no luck with the details
   503DBD  CFG1692                                                        2018/05/27 05:24:12
   503DBD  CFG1693                                                        2018/05/27 11:53:08
   503DBD  CFG1486                                                        2018/05/27 15:17:15
You have named it as 503BDB in the reply to my post, but you have named it correctly in the reply to AoDs post.
So, can you please check the database, that it is in as 503DBD,LY-NVY,1909,Airbus A320-214,Avion Express/Condor and not as 503BDB,LY-NVY,1909,Airbus A320-214,Avion Express/Condor added Friday 25/5. Many thanks!
Regards Ingo
400M23R
3E291C is yet another miscode of D-IMVC BB-1741 B200 Starwings
Kind regards
Graham
Morning Ingo
3D49DE,D-FAFM,1226,Socata TBM 930 added yesterday after post from EK01
3E5F53,D-KBHJ,1062,Valentin Taifun 17E
3FF50F,D-MBPR,,Zenair CH 601 Zodiac
503DBD as per attached
Nothing on the others
I will look at the autopopulate when I get home tonight.  My main computer has not been updated for a month and I will be back to decent internet.  I know however that a new one picked up in my hotel in Bilbao populated within seconds on Saturday night.
Afternoon Alan,
IBE2948 : LEMD-LGAV
IBE2949 : LGAV-LEMD
ENT565L : LEMD-LGMK
WZZ5SU : LEMD-LRCV
JAF6BK : EBBR-GMMW
ANE21SJ : LEPA-LEAM
ANE8957 : LEMH-LEMD
BEE715A : EGHH-LEAL
TVQ6237 : LEAM-LZIB
EXS57C : EGCC-LEAL
EXS970 : LEAL-EGCC
EXS96W : EGCC-LEAL
Not populating : 385B9B
Flight id : F-WKVD
The registration relates to an ATR 42-600 c/n 1005. However I believe this to possibly be an often used ATR manufacturing hex code.
Evening Ian, now safely back home and its a balmy 25 degrees when I got here, very nice
F-WKVD is indeed an ATR test/ferry registration which has been used on 6 or 7 frames.  On this occasion it is c/n 829 ATR 72-212A for Afrijet and  ferried LFBF-LFBO GMMN for painting
CarlosAbreu
28-05-2018 Updated file in attach.
Carlos
yang
ACA017   Vancouver (CYVR) ---> Taipei (RCTP)
ACA018   Taipei (RCTP) ---> Vancouver (CYVR)
Good morning Alan, Monday unknowns:
3DD2CD  HELI411 (2x) according to flightaware: D-HABT, http://www.helionline.net/photogallery///52388.html
3E211C  DIMVC either some very bad packets received or it's that one https://planefinder.net/data/aircraft/D-IMVC miscoded
MILs:
   3E4D21  EIFEL                                                          2018/05/28 19:56:46
   3E8353  PACK42                                                         2018/05/28 14:07:18
* 3E88C2  PACK22                                                         2018/05/28 07:26:53
* 3E88C2  PACK41                                                         2018/05/28 14:06:56
* 3E96F3  GAF639                                                         2018/05/28 09:45:38
* 3E96F3        2018/05/28 10:52:10
   3E9FDF        2018/05/28 13:29:57
   3E9FDF  PANTER2                                                        2018/05/28 18:00:25
* 3EA3E5        2018/05/28 06:57:35
   3EAACA  PACK21                                                         2018/05/28 07:26:53
   3EAF48  LION1                                                          2018/05/28 17:50:00
   3EBEFA        2018/05/28 13:14:41
   3EBEFA        2018/05/28 17:50:57
   3F401B        2018/05/28 07:39:31
   3F6479  RAVEN1                                                         2018/05/28 06:58:14
* 3F667C        2018/05/28 13:19:16
* 3F667C        2018/05/28 14:03:23
   3F7CA4  KNIGHT1                                                        2018/05/28 19:40:55
   3F7CA4  KNIGHT1                                                        2018/05/28 20:09:13
   3F867C        2018/05/28 12:13:00
   3F9461        2018/05/28 12:12:38
   3F9461        2018/05/28 13:08:49
   3F9CFB        2018/05/28 09:11:42
   3F9D29        2018/05/28 08:00:30
   3F9D29  PANTR1                                                         2018/05/28 17:58:54
   3FA364        2018/05/28 07:45:59
   3FB5D8  SCARE                                                          2018/05/28 06:43:53
3FEB4E  DMIAK https://www.planespotters.net/photos/reg/D-MIAK (latest picture etc. I found is 5 years old)
3FF4E9  DMHCY again and nothing new to report.
Regards Ingo
diddyboy
Hi Alan
Finally back on after an absence due to computer malfunctions, an EasyJet not populating from yesterday:
4403BB  EZY58CU  EGGP-LPFR                                             2018/05/28 08:58:39
4403BB  EZY85VP  LPFR-EGGP                                             2018/05/28 14:07:07
regards
Neil
