0 Members and 59 Guests are viewing this topic.
Morning Ingo
3E7B84,D-KLYY,28/461,Schempp-Hirth Ventus 2cM
505C4F,OM-S444,053,Shark Aero Shark
Mil tac added, I added 3E4D21
X
#15138
192657 is possibly IL76MDK RF-75351 of Roscosmos (00834 81431)
* 192657        2018/05/30 15:28:27
The Second showed up twice so not sure if it is a true hex or a corrupt signal
* 42424A        2018/05/30 12:59:42
Third I"ll bet you have no idea! Neither do I except it was at chopper height:)
* 999111        2018/05/30 12:17:10
PS VP-BZC E190 is Ikar Airlines but with Pegasfly titles on a white body and tail
X
Or leave it blank as I have done
Thanks again Terry
Hi X
192657 doesn't decode so no idea of it is RF-75351
42424A unknown to me
99111 no idea on it either
Thanks for the info on VP-BZC
#15141
Good morning Alan, Wednesdays unknowns:
MILs:
   3E83B7  GAF723                                                         2018/05/30 13:05:28
   3E869B  GAF640                                                         2018/05/30 07:22:09
   3E869B        2018/05/30 13:20:04
3FF680  DMAXF still nothing new to report
Regards Ingo
Morning Ingo
Mil tac added and nothing on 3FF680
Michel
Alan,
BMS9SN EGGW-LRCL
CLU804 EGSS-EDDF-KATL
CND113 EHAM-
EXS4PK EGPF-LGKR
EXS448 LGZA-EGNM
EXS89AV LGZA-EGPF
EXS978 LGZA-EHAM
SIA7360 WSSS-OMSJ-EHAM
TCX590 EGSH-LTBS
TFL175 EHAM-LDPL
VKG1411 LEPA-ESOK
Michel
X
Alan/ffa
192657 is using the recent Russian hex system which historically would be 152657 which decoded to RA-75351 therefore most likely is RF-75351(which is based at Moscow Chkalovsk) used for No Gravity flights by Roscosmos.
The same as below where 140AE5 decodes to RA-02789 therefore 180AE5 is most likely either RA- / RF-02789 or RA-2789G but I cannot find anything on it just yet. Maybe ffa can help. It was never above 1400 ft so likely a new chopper.
* 180AE5        2018/05/31 13:07:30
X
Thanks X, I await some confirmation on these
