0 Members and 41 Guests are viewing this topic.
Moved here from a separate thread
* 05A080  8QRAZ                                                          2018/12/14 08:32:44
* 093120        2018/12/14 12:55:38
* 128FF0        2018/12/14 09:38:48
   345307  AED354                                                         2018/12/14 16:10:50
* 39484A        2018/12/14 10:13:56
* 3CF466        2018/12/14 13:23:21
* 4CF3A6        2018/12/14 13:36:15
* E32FE0        2018/12/14 09:42:08
   004000        2018/12/15 11:18:39
* 121B4C        2018/12/15 11:17:25
* 12CF4C        2018/12/15 11:17:23
   200408        2018/12/15 07:37:41
* 93A49B        2018/12/15 13:44:52
* F7303E        2018/12/15 10:54:17
Andy
05A080,8Q-RAZ,1506,Aerospatiale ATR 72-600,Manta Air
345307,EC-340,VARIOUS,Airbus A330-243 MRTT,Airbus Military Test Registration
093120 no country allocation
128FF0 within the Russian allocated but code no allocated
39484A decodes to F-GSCK but not allocated on the French register
3CF466 decodes to D-CTVY but not allocated as far as I can see
4CF3A6 within the codes for Montenegro but unknown to me
E32FE0 no country allocation
004000 within the Zambian allocation
121B4C within the Russian allocation but does not decode
12CF4C within the Russian allocation but does not decode
200408 no country allocation
93A49B no country allocation
F7303E no country allocation
Your miscode can be anything from a corrupt packet received by your receiver to a signal from a phone mast etc, note there is no flight ID associated with them.  Only ones that has an ID were aircraft
CarlosAbreu
15-12-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
* 0F2289        2018/12/16 18:28:57
* 1205AE        2018/12/16 07:31:34
* 1216D4        2018/12/16 07:31:34
* 171818        2018/12/16 19:39:15
* 17327F        2018/12/16 13:57:52
* 1A6A76        2018/12/16 11:35:44
* 200475        2018/12/16 14:15:01
* 397F49        2018/12/16 14:23:22
* 39C549        2018/12/16 14:23:22
* 472084        2018/12/16 07:41:51
* 477D84        2018/12/16 07:41:49
* 4D7DB3        2018/12/16 12:47:23
#16552
Morning Terry
Both the Norwegian 787's are in the air at this time using NAX flight ID's and not the Long Haul ID of NLH but I cant remembers that last time I saw the code used
#16553
Andy
The only one from your list that decodes is:
39C549 which decodes to F-HRKJ which is not allocated on the French register
Again the others are either unknown miscodes or corrupt packets and again no flight ID's which suggests corrupt packets but they may also be coming from non-aircraft sources
hf.radionorthwest
CarlosAbreu
16-12-2018 Updated file in attach.
Carlos
Evening Terry, thanks again
CarlosAbreu
17-12-2018 Updated file in attach.
Carlos
