0 Members and 56 Guests are viewing this topic.
lusitani
ModeS: 8990FD
Registration: B-89001
Type code: DA42
Type: Diamond DA42 NG Turbo Twin Star
Airline: APEX Flight Academy Co., Ltd.
89903D
NA-103
Eurocopter AS365 Dauphin
National Airborne Service Corps, Ministry of the Interior, Taiwan
A8EA3A
NA-103
AAFB6D
NA-302
BEECHCRAFT KING AIR 350
89907F
B-5556
Dornier Do 228
Daily Air
M
VIR206   EGLL   VHHH
AUA2643   LOWW   ENBO   via EDDM
AUA2644   ENBO   LOWW   via EDDM
4A98B0 / SE-FEP / C182 / Cessna 182M Skylane / Private (Mattias Nordin) / 18259395
Miscoded aircraft (allocated 460140):
484549 / OH-AMI / P28A / Piper PA-28-181 Archer II / Private / 28-7890268  (ex PH-VLK)
X
#1682
By your post it appears A6-ABR went straight to SU-BQK, but that does not fit my records as A6-ABR was last seen 24th April but was noted as JY-PTD in my log and pinged as such 16th May as JAD998 on departure SHJ.  So sequence should be A6-ABR/JY-PTD/SU-BQK,
As I stated A6-ABM went JY-PTC in November last year and seems to have returned SHJ yesterday but what it is wearing I have no idea. Might be just for service but when I pick it up again I will let you know.
X
X
#1683
QTR1064   OTHH-OMDB             A7-ADD     A320  Qatar Airways        2015/07/17 18:03:25
QTR1065   OMDB-OTHH             A7-ADD     A320  Qatar Airways        2015/07/17 20:10:33
ABY1195   OMSJ-OEAB               A6-ANV     A320  Air Arabia           2015/07/17 13:57:38
ABY1196   OEAB-OMSJ               A6-ANV     A320  Air Arabia           2015/07/17 19:35:01
FDB7937   OMDB-OEJN               A6-FDJ     B738  flydubai             2015/07/17 21:40:22
FDB7938   OEJN-OMDB
X
Thanks again Kenny.
Noted those hex codes on your log but still unknown to me at this time.
Many thanks Lusitania.
For info B89001 is c/n 42.N002
I have details on NA-302 and it is c/n FL-108 however the hex code of AAFBRD is active in the US as N80663 so I can only add it to the database AS various and in use by the different aircraft.
Similarly A8EA3A decodes to N6737R in use on a Cessna T210F Turbo Centurion so the same would apply to this hex.
I can find no details of the c/n for B-5556
Many thanks for your assistance.
Thanks X,
I can only go with what I get on my d/b or via the internet and eyeballs are usually the best.  Until any info on JY-PTD comes into the public domain I have no way of knowing if it has returned.
X
Understood, but as I said I believe that some of the sites are mixed up and have made a booboo as A6-ABR/JY-PTD c/n 3925 is in service today as SU-BQK and can be seen on FR24, but JY-PTC/A6-ABM c/n 3246 has not been noted recently. Yesterday it was pinging as ADSB equipped however I cannot see it on FR24 which is strange.
X
#1690
Many thanks for the route info X.  Yes agreed you can get different info depending on the site visited and is evident on the info I gave last night.  My d/b gives JY-PTD as c/n 3246 and does not have any info on JY-PTC.
flygfantast
Not populating, on delivery:
4BCCAE TC-SEN, Boeing 737-8HC, c/n 61174/5486, Sun Express
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks Niklas, now added correctly, I had it in with a corrupt hex.
X
#1693
I have to say your db must be wrong or something very odd has happened as I read off JY-PTC in November 2014 at the SHJ hangars, the day after it last flew as A6-ABM (c/n 3246). A6-ABR (c/n 3925) was still flying as A6-ABR till 24 April 2015 (see below my last pick up) so JY-PTD cannot be c/n 3246 unless something very odd has happened such as JY-PTC being reregistered to JY-PTD.
    89626D                           A6-ABR     A320  Air Arabia           2015/04/24 05:30:27
As I stated JY-PTC was eyeballed 26 November and A6-ABM hex 896375 was not seen since 25 November except once in March and then again yesterday which I believe are service intervals.
This is what I have when JY-PTD departed 16 May which coincides with the disappearance of A6-ABR at the end of April.
* 744284  JAD998               JY-PTD      A320  Air Arabia Jordan2015/05/16 10:30:18
NB the db has 744284 as JY-PTD c/n 3925 and the hex code fits in sequence of all four Petra/airarabia regs
X
M
