0 Members and 136 Guests are viewing this topic.
Alan,
Got EI-SEV approaching from a strange direction and wondered what it was doing. The easyJet definitely showed the departure airport as LELC on my AN screen and not LEMI. Having said that do I need to do an airports database update ?
Alan,
In answer to a request some time ago and now appearing in the French register :
F-HGIM Cessna 680A c/n 680A-0173 owned by Lixxbail. Hex code not given.
If you have it on your screen before I make the change it wont take effect until the next time you pick it up.  The RYR inbound from Stansted should show OK see attached
Thanks Ian, its in the d/b
Alan,
Confirming that the Ryanair inbound from Stansted did show LEMI on the AN box. At this stage there doesn't appear to be a set flight path for arrivals as the Ryanair is approaching from further south than the previous two.
I now have a non-populator :
3B9BDB with the flight id showing as ?????? no further info.
#16835
Just got to watch for it going back out now to see what the outbound ID is.
RYR2322 just departed Leeds it was RYR33PH last week into LELC
3B9BDB,13,13,Breguet Atlantique 2NG,France - Navy
Alan,
The return to Stansted was RYR8027.
Yes I got it and added it in and showing as such on the network.
#16838
Have the RYR2154 inbound from Birmingham and probably amended it to late for you
EZY7427 inbound from Southend next
Alan,
RYR2154 : EGBB-LEMI
RYR2155 : LEMI-EGBB
RYR2323 : LEMI-EGNM
The Ryanair flights would appear to be using the flight number details as per the arrivals/departures board (at least for now).  The same goes for the EZY7427. It should be EZY7428 for the return according to the departures board.
Yes Ian it would appear that way,  The EZY is away and is as you suggest.
CarlosAbreu
15-01-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Terry, thanks again
Afternoon Alan,
Not populating :
3B7B23 FL220 Flight id : FDO8303
