0 Members and 170 Guests are viewing this topic.
CarlosAbreu
17-01-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Thanks for the update on G-NPTD. Still can find nothing on VQ-BFS ATRAN B738F c/n 32616/1212 arriving VKO, under that registration or previous one N453SR.
X
Morning Alan,
Out of Corvera using same flight id when routing to San Javier but obviously airport ICAO changed.
EZY8550 : LEMI-EGKK
The arrival was : EZY8549.
Nothing my end X, guess we will need to wait on its next flight
X
#16867
First noted Aug 2017 finally nailed today!
   19074D        2019/01/18 13:00:00
   19074D        2019/01/18 14:05:03
19074D (15074D) is RA-67405 Cessna 182 c/n 18281641
X
#16868
Is that a confirmed miscode or an assumption on your part X
X
I do not think it should be classed as a miscode nowadays, as the Russians registry seems to be deliberately using 18xxxx and 19xxxx usually for smaller  aircraft instead of 14xxxx and 15xxxx which tend to be larger (or older) aircraft. Same as 1Axxxx and 1Bxxxx are seemingly military and 1Exxxx and 1Fxxxx are factory numbers based on the old 14xxxx and 15xxxx system. 10xxxx and 11xxxx appear to be used on ground equipment codes as 10C351 (RA50001 NB no hyphen) was seen today at DME.
X
X
heading towards MOW from the east is 154C83 RA-85123 this is a Tu-154M, any idea of the operator
Yes X but the question I would ask is, is it confirmed as there is no details in the flight ID and I don't believe it to be good practice to put unsubstantiated data into the d/b ?
X
#16872
RA-85123 was last noted in 2016 as Kontinent (AviaPrad c/s), but with "This Day Congratulations to Russian military Fleet" body t/s but was then stored Samara so seems to be on the move again. As it appears to be going to Chkalovsk I can only think it is Air Force/military now, as no one other than Alrosa operates Tu154's nowadays
X
X
#16873
ffa confirmed 2017 that RA-67405 was using 19074D
X
That's all I was asking for, some confirmation X.  Does that mean therefore that 15074D should be deleted
