0 Members and 106 Guests are viewing this topic.
Afternoon Ian,  RYR2322 was added in on 15th so should have come up ok
That's it amended Ingo.  One of the problems with re-issuing registrations
X
* 500153  T7PAM                                                          2019/01/19 20:35:54
New one I assume
X
X
I have it as 500153,T7-PAM,14501017,Embraer ERJ 135BJ Legacy 600,Hyperion Aviation/Bookajet Aircraft Management,
hf.radionorthwest
hi alan
some more just showing codes
* 120006        2019/01/19 07:10:15
* 1206EF        2019/01/19 12:43:53
* 122C2A        2019/01/19 13:54:54
* 12340E        2019/01/19 12:38:34
* 143A76        2019/01/19 11:33:56
* 37E4D7        2019/01/19 07:36:26
* 94E411        2019/01/19 07:36:26
* 9F3660        2019/01/19 11:20:08
* A13660        2019/01/19 11:20:10
* E4E47D        2019/01/19 07:13:54
andy
Hi Andy
The only one which may be a real code would be A13660 which decodes to N1776H but this in unallocated.  143A76 also decodes to RA-14966 again unallocated
These may be non-aircraft transmissions or possibly even spoof ones put out by the military but they don't tend to do much at the weekends
Good morning Alan, Saturdays unknowns:
3D85BA  DFWWW https://www.jetphotos.com/registration/D-FWWW
3FF4E9  DMHCY still no luck with the details
3FF64C  DMDRE (2x) it's the same with that one
7585A1  RPC4118 https://xfw-spotter.blogspot.com/2018/11/a321-271nx-cebu-pacific-d-avyc-rp-c4118.html already added I guess
* 7815FE  CDCB306A                                                       2019/01/19 12:18:58
* 7815FE  B306A                                                          2019/01/19 12:23:11
https://xfw-spotter.blogspot.com/2019/01/a320-251n-zhejiang-loong-airlines-d.html already added too, I guess
Have a nice Sunday!
Regards Ingo
Afternoon Ingo
3D85BA,D-FWWW,1270,Pilatus PC-12/47E
Nothing either on the ultralights
RP-C4118 added in yesterday and B-306A was missed yesterday but now added in
Morning Terry, thanks again
Afternoon Alan,
Not populating : 4911EC
Flight id : VVV611          The VVV equates to Valair.
Flight Level : 230
Also for Corvera (LEMI) the weather details do show (at least, I assume they are for Corvera) as it comes up as 'station name not available' for Corvera.
Anything I need to do to have the system recognise LEMI or is this a job for a higher authority !
Afternoon Ian
4911EC,CS-DOL,525B-0330,Cessna 525B CitationJet CJ3
I insert LEMI into the airport box then click get weather and the weather  comes up ok per attached
Alan,
If you enter LEMI in the airport box and then go into the 'Get Weather' box and ask for the decoded Metar, the weather does come up but it states 'station name not available '.
The METAR itself and the TAF are OK.  however it states LEMI on the second bottom line of the decoded METAR.  Probably something to do with the airport code coming into action 10 years after the software came out.  Don't look to get anything done about it anytime soon
Hopefully you will remember which airport you asked the weather for :-))
Alan,
So it does.
I only check the weather when it is raining in order to find out when the sun will be returning therefore I am not on this facility very often !
