0 Members and 23 Guests are viewing this topic.
X
#17310
RF-78652 was "apparently" photographed at Chakalovsk on 7/3/19 (russiaplanes.net) but shot is nose on so one cannot see the reg, but I did pick it up.... and the reg in db is wrong as it shows 1E333A RF-76852 (should be 78652) but ffa states he saw it and 1E333A is now RF-78654!! It is very confusing I hope another photo side on comes up soon.
RF-78651 is now NO prefix 78651, an Ilyushin A-100 prototype (fitted with AWACS dome) It was an IL-76MD-90A and is operated by KB Beriev (TANTK)
X
hf.radionorthwest
hi alan
   406CAA  EXS936   LIMF-EGCC       G-GDFU     B738  Jet2.com             2019/03/09 12:49:24  [**1 to add**]
andy
Afternoon Alan,
Obviously you take the info from Military Mode S at your own risk as they have both 35350D and 35350E as P.3M-12.
Noted X and ffa
Andy
For info this flight used EXS7GT last week!!
Aye good one, thanks Ian
AoD
company update:
49D34B,  OK-EUP,  Lion Helicopters
49D2A5,  OK-CAB,  Lion Helicopters
Hi AoD, operators amended
Many thanks
ffa1978
Quote from: X on March 09, 2019, 12:02:05 PM
ffa
Thanks for the email confirming your sighting 1E333A as being RF-78654 as it was noted previously on RF-78652. As stated in my post It should use 1F333E.
Maybe once an aircraft moves to the UVD740mhz freqency, the engineers are just moving the same box from plane to plane and not changing the hex miscode as 1E333A decodes to RA/RF-13114.
I also note that RF-78655 and RF-78656 are moving around and ought to be 1F333F and 1F3340 but if VVS (BBC) machines will probably only use UVD740mhz to ping. Have you noted those?
X
RF-78655 1f333f   RF-78656 1f3340 seen 25 january and 06 march .From december 2018 not using uvd 740 transponders
CarlosAbreu
09-03-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Terry, thanks for those
Morning Carlos, thanks again
Morning Alan,
RYR8SG : EDDK-LEAL
RYR578C : EGCC-LEAL
EVE1325 : LEVC-LEMG
AEA95PF : LEST-LEAL
VLG2XC : LEJR-LEPA
EXS879 : EGCC-LEAL
Morning Ian, thanks again
#17324
Afternoon Terry, thanks again.  I wonder if any of your last batch will actually have a transponder fitted
