0 Members and 38 Guests are viewing this topic.
You should either click on the plot or on the grid.  It may however have already been in focus by itself so will not update but if you wait until it goes off your coverage update it through Mylog/Populate or even do a database update as it is in todays update.
X
I tried both plot and grid but it is now on the ground so I will try the Mylog/populate, if not will do another download as I did one yesterday
Thanks, I assume EI-EYM might also go VP-/VQ- soon so will be waiting for another unknown Rossiya imminently
X
Afternoon Alan,
SCR378 delete this route from the d/b as it gives it as NZNS-NZAA and I don't think coming overhead here is within that routing !!
BAW2544 : EGKK-LEAL
RAM8729 : LFML-GMMN
AUA36BL : LEZL-LOWK
VLG3302 : LEIB-LIRF
VLG3303 : LIRF-LEIB
IBE32SW : LEMD-LICC
TCX1928 : EGGD-LEPA it then changed flight id at Palma to TCX1929 and routed LEPA-GCRR.
X
B-306J just went OTT me and was an A21N
X
SCR378 is a current flight ID operating Nelson-Auckland operated today by DH8C VH-TQL and it landed around 2 hours ago.  What was using it when you picked it up?
X, it was added into the d/b on departure from XFW so should populate.  Do you have Auto-Populate aircraft data ticked in Preferences?
X
Populated as an A20N
Auto populate ticked
X
Afternoon Alan,
It was being used by D-CSCA a Cessna 525B of Silver Cloud Air with flight id SCR378 whose ICAO code is SCR.
Evening Ian
Unfortunately Eastern Australian Airlines operate Jetstar Airways flights in  New Zealand using SCR flight ID's using 5 Dash 8's
https://en.wikipedia.org/wiki/Eastern_Australia_Airlines
#17906
Alan,
I would imagine that the conflict is a rare occurrence with being at opposite ends of the world.
AUA35LV : LOWK-LEZL
ENT7117 : EPKT-GCLP
JAF6DQ : EBCI-GMMW
VOE2SW : LEMG-LFMN
TVF89RD : LFLL-GMFO
SQP791 : UKBB-GCTS
RAM952Q : GMMN-LIPE
DAH1087 : LFPO-DAON
SVA226 : LEMD-OEJN
EDIT : Naughty Eastern Australia Airlines, they should be using ICAO code 'EAQ'.
Hi Ian
Don't think I have ever seen EAQ as they don't usually flight their own routes
X
* 155BA3        2019/04/30 23:09:50
* 781617  B306D                                                          2019/04/30 20:51:00
155BA3 decodes to RA-88995 which I do not know but most likely a poor signal from 155BE3 SU95 which was around at same time, the second you probably got on take off
X
CarlosAbreu
30-04-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
