0 Members and 49 Guests are viewing this topic.
CarlosAbreu
05-07-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
yang
75855D is RP-C9935, not RP-C5909.
#18422
Hi Yang
Unfortunately both aircraft are using the same code, see below a message on mode-s forum posted on the delivery of RP-C9935
A21N MSN 8568 was delivered yesterday as PAL5005 XFW-AUH-MNL
Its using hex 75855D which is already in use by Dash 8 RP-C5909 delivered in
June
Also further message posted 27th November
Hallo all, looks like this miscode may be with us for a while as the A321 operated PR539/540 MNL-CGK on 27th Nov (bit far for a DH8D) and FR24 is showing these flights as operated DH8D by RPC5909 on FR24 flight history.
At the same time RPC5909 was also doing local flights in the Phillipines, so unfortunately it seems they are both using 75855D.
So much for hoping it was just an error on delivery. Ah well back to the old school way of recognizing the difference between a DH8D and a A321 then. Think I just about have it in me.
The DH8D uses a GAP flight ID and the A21N a PAL flight ID.  I presume the A21N is the miscode as the DH8D was delivered a few months previous
X
#18424
Alan/ffa
I have a strange one here showing on both FR24 and Planefinder!
49D37F claiming to be OK-TSP smartwings B738 but call sign OK-JPT (L410 c/n 30 19) flying out of Kubinka to ZIA and now heading east at 11000ft and only 190knots which is more like a military L410. I cannot confirm what reg it now carries however when you search OK-JPT on russianplanes.net it shows RF-67758 Лет Л-410УВП-Э20 (with floats). I can only assume 49D37F as OK-TSP is a reuse of the old OK-JPT hex.
X
#18425
X can't check just now as I am in Santander waiting to board the ferry home.  I added a new Smartwngs the other day, may have been TSP. But maybe not. The easy way to check is to search the hex on the Czech register which is updated daily
and that will show if its current.  Hex codes can be reused on different registrations
X
#18426
49D37F OK-TSP was a reg used by A6-FDH B738 of flydubai when leased to smartwings a while back in 2017, OK-TSV i think is the most recent addition to the smartwings fleet. I can find no recent history for OK-TSP it only shows the L410 movements between Kazan, Ekaterinberg and Moscow. I believe it is now RF-67758 but needs confirming.
Enjoy your trip home
X
#18427
X
Now set sail and I have internet access again.  49D37F is not allocated at present and is not allocated to OK-TSP in the database I am please to advise.  It has been used twice that I can see from the Czech register.  Once by OK-TSP and once by L410 c/n 3101 which will make it RF-67758 which as you stated earlier is float equipped
X
#18428
Russianplanes have it reported a c/n 30 19, thats why I stated needs confirming however if Czech register is correct maybe they have it wrong
X
CarlosAbreu
06-07-2019 Updated file in attach.
Carlos
ffa1978
#18430
Quote from: X on July 06, 2019, 03:55:16 PM
X
Yes its RF-67758 (ex-OK-JPT) Russian Air Force (produce on Ural Civil Aviation Fabric) Now don't have float https://russianplanes.net/id251141
paul tricker
A few that didn't populate...
A58420   N45458   PA-18-150 Super Cub  18-8553
4077F3   G-ISMC   Reims Cessna F152    F15201468   Stapleford Flying Club
485D30  PH-NNX   Cessna C750X         750-0232    JetNetherlands
4020F3  G-BZVB    Cessna FR172H      0327      Victor Bravo Group
04018B  ET-AXO    Boeing 737-8AL    39051     Ethiopian Airlines
A9CCA9  N730SP   Cessna 172S    172S8667
4077EE  G-IOVE   Brissell NG5 Speed Wing  LAA385-15556  S.D.Austen
440415  OE-IIP   DHC-8-402    4539   Celestial Aviation Trading
4045B5  G-POGO  Flight Design CT2K   01-06-02-12  P.J.Reilly
38FC1B  F-AZPF    Fouga CM-175 Zephyr  28
Have a safe crossing
Paul
Carlos
What database are you using.  Therer is no route information in the database for RCH flights as it was all removed 3 or 4 years ago
Also OK-JRS is in the database as a C680 not a P22T a type code that does not exist?  maybe you need to update your database?
