0 Members and 101 Guests are viewing this topic.
Michel
Alan,
TRA274 LTBJ-EHAM iso LTBS-EHAM
TRA75A EHAM-LGTS
TFL290 LGKR-EHAM
NAX5194 LEBL-EKBI
AIZ2513 LLBG-EHAM
UAE9987 OMDW-EHAM-KORD
TRA1131 EHAM-LTFG
TRA2061 EHAM-GCLP
TRA1477 EHAM-LEPA
TFL795 EHAM-LTBS iso EHAM-LTBJ
CND114 LTAI-EHAM iso LEPA-EHAM
TFL621 EHAM-LEPA
TFL271 EHAM-LGMT
Michel.
flygfantast
Not populating:
49C002 c/s OKMUU
3CC95A c/s DCDOC, D-CDOC Learjet 45, c/n 45-018 (ex OO-LFS)
See http://forum.luftfahrtclubbraunschweig.de/21-07-2015-brandneue-reg-learjet-45-d-cdoc-t4371.html
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi Niklas,
Nothing on the Czech register yet for the hex or the registration.
Many thanks
Neil,
A266D5 arrived Wick this evening and identified as B190 N258SL miscoding instead of using its allocated A276D1.
CYYZGUY
40" LED Monitor
40" LED Monitor
Kenny
3FEE7C HS-BON Flight Design CTLS cn: F-11-10-03  op AE-Adventure Co. Ltd  still miscoded
RNA401  VNKT  VTBS
RNA402  VTBS  VNKT
CCA811  ZBTJ VTBS
CCA812  VTBS ZBTJ
THD270  VTSP  VTBD
LAO441  VLVT  VTBS
LAO442  VTBS  VLVT
Kenny
ANRB 3km north of VTBD
Many thanks Kenny.
Unfortunately there is a new 3FEE7C D-MBTY FDCT flying in Germany so I think it would be better if we left it alone and you made the manual addition to your local database with HS-BON.  The alternative would be to amend the details for the hex to VARIOUS as the registration and append the details show that it is in use by more than one aircraft.
X
#1884
* 09A039        2015/08/01 02:12:13
* A9E8C4        2015/08/01 11:03:44
* A9E8C4        2015/08/01 16:05:31
A9E8C4 decodes to N738AA C172 but that was sold to Canada in 1979 but this one was climbing thru 15000ft we think it might be Aramco pig N738A miscoding. Gambian only had two pings so will probably be spurious
X
Good Afternoon, unknowns July 29th:
343513 nothing more
* 3C17C5  AIB719A                                                        2015/07/29 14:08:11
* 3C17C5        2015/07/29 15:03:03
D-AYAA A321 Test Reg: http://xfw-spotter.blogspot.de/2015/07/a321-211sl-air-berlin-d-ayaa-d-abcr-msn.html
* 3C17C7  AIB725A                                                        2015/07/29 08:14:07
D-AYAC A321 Test Reg: http://xfw-spotter.blogspot.de/2015/07/a321-231sl-jetblue-d-ayac-n954jb-msn.html
3C543C nothing more
3C64DA nothing more
3D24A4 decodes D-EMCY nothing about a new airframe with this reg/hex.
E80446  LAN9903 A321 on delivery, as far as I can remember, this ones has already populated.
MILs:
* 3F8CE8  GAF640                                                         2015/07/29 06:23:27
* 3F8CE8  GAF640                                                         2015/07/29 13:10:24
* 3FAAE1        2015/07/29 10:21:16
Regards Ingo
Unknowns from July 30th:
0A8D35 nothing more
18094C nothing more
347CFF nothing more
3C17C6  AIB723A
D-AYAB A321 Test Reg: http://xfw-spotter.blogspot.de/2015/07/a321-231sl-american-airlines-d-avab.html
3E1F56  DIDAS http://www.flugzeugbilder.de/show.php?id=1355797
49C110  OKUUA85 no further information
49D021  OKKLM http://www.flightradar24.com/data/airplanes/ok-imc/
4B39FE nothing more
4CAAB3 nothing more
505E9E nothing more
780E4F  CSC8326 A320 on delivery should already be added...
A414B5 could be N104MT using wrong ICAO (did so on July 25th)
ACC9D8 decodes N923FM not assigned/reserved by FAA
DD0204 no country allocation
MILs:
* 3E9758  GAF723                                                         2015/07/30 10:08:18
   3F4F45        2015/07/30 11:54:57
* 3F655B  EAGLE                                                          2015/07/30 07:54:59
* 3FB618  HG01B                                                          2015/07/30 12:25:20
Regards Ingo
Unknowns July 31st:
150720 nothing more
3CC95A  DCDOC http://www.luftfahrtclubbraunschweig.de/picdb/Uwe-Bethke-Unbekannt-Bombardier-Aerospace-Learjet-45-D-CDOC-BWE-Braunschweig-Wolfsburg-13379.html and http://www.planepictures.net/show.php?id=1368438
3D2EF4  DEQAM http://www.luftsportring.de/flugzeuge/aquila-211-d-eqam/
3D5D16  DFHMS https://planefinder.net/data/aircraft/D-FHMS
3E6412  DKDCC http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=611516B9255FC0912FCFC079F20264DC?dsId=4509838 and is owned by http://www.lsccr.de/welcome-discus-2ct/
3E66E5  DKEDX http://www.flight-board.com/viewtopic.php?f=28&t=2110
3E8A4A GAF MIL/TAC
3FF304  DMIRI no further information
3FF308  DMHLB D-MHLB SC-07 Speed Cruiser http://www.abpic.co.uk/photo/1491415/
3FF360  DMLUE no further information
3FF362  ZZZZZZZZ no further information
3FF3CB  DMNEE still no luck with the details
3FF3EC  DMHYU same as above
485192  PH1558 http://www.acnistelrode.nl/onze-vloot/
4851A9  PHJIT PH-JIT Diamond DA 40 NG Star   40.N285 150615 8536 http://landewers.net/PH.txt
4B4035 http://www.bazl.admin.ch/experten/luftfahrzeuge/luftfahrzeugregister/index.html?&lfrSucheDetailKnz=HB-YIF
4BA8DF nothing more
505E61  EAT492 OM-SAA
50832A nothing more
508339 nothing more
5803CD no country allocation
Have a nice rest-weekend!
Regards Ingo
Ingo,
29th
3C17C5,D-AYAA,VARIOUS,Various A321 Airframes,Airbus Test Registration
3C17C7,D-AYAC,VARIOUS,Various A321 Airframes,Airbus Test Registration
3D24A4,D-EMCY,205-0364,Cessna 205
E80446 CC-BEE A321 already in d/b
Nothing on the others and mil tac added
