0 Members and 91 Guests are viewing this topic.
Ingo,
30th
3C17C6,D-AYAB,VARIOUS,Various A321 Airframes,Airbus Test Registration
3E1F56  D-IDAS miscode allocated 3E1F46
49D021,OK-KLM,4692140,Piper PA-46R-350T Malibu Matrix,Flying Academy
780E4F B-8326 A320 already in d/b
A414B5 N104MT miscoded
ACC9D8 decodes N923FM not assigned/reserved by FAA
Nothing on the others and mil tac added
I did a re-check of 3E1F56 DIDAS:  3E1F46 D-IDAS wasn't miscoded, the entry was caused by some corrupted packets that my box had received.
Regards Ingo
Ingo,
31st
3CC95A,D-CDOC,45-018,Learjet 45
3D2EF4,D-EQAM,AT01-300,Aquila AT01,Bundeswehr-Luftsportring Laupheim
3D5D16,D-FHMS,1487,Pilatus PC-12/47E
3E6412,D-KDCC,,Schempp-Hirth Discus 2T/18,Luftsport Club Castrop-Rauxel
3E66E5,D-KEDX,,Diamond HK36TTS Super Dimona
3FF308,D-MHLB,SC07-028,BOT SC-07 Speed Cruiser
3FF360,D-MLUE,1409-7339,Ikarus C42C
485192,PH-1558,23098,Schleicher ASK-23B
4851A9,PH-JIT,40.N285,Diamond DA 40 NG Star
4B4035,HB-YIF,013LSA,Breezer Aircraft Breezer,Felix Imhof
505E61  EAT492 OM-SAA now G-RAJG B734
Many thanks and enjoy your Sunday
Thanks for the info on D-IDAS Ingo
flygfantast
4AD838 SE-VAX, Flight Design CT2K , c/n 03-05-03-22, BFK
Also 3CC95A D-CDOC still doesn't populate.
Niklas
Cable: Ecoflex-10 (10m+1m)
Niklas,
I had messed up the hex when inputting it but corrected it an hour or so ago so it should be OK now.
Many thanks
3D5D16,D-FHMS,1487,Pilatus PC-12/47E does not populate
Can you check this one please? Thanks!
Its in OK Ingo, 3D5D16,D-FHMS,1487,Pilatus PC-12/47E is straight out off the server.
A question:
why a A210 (AT-01) although A211 is on the airframe and the operator states that it is a Aquila 211?
http://www.luftsportring.de/flugzeuge/aquila-211-d-eqam/
Mainly because the ICAO A211 is for the  Alfa-M A-211.  The marketing name A 210 is usually used to refer to Aquila's light side by side two seat aircraft, though its official engineering and certification name is Aquila AT01 and that is what we have standardised to and use the ICAO A210.
There are 3 marketing variants
Aquila A210 Original model Aquila A211 Conventional instrument panel Aquila A 211GX Glass cockpit model
Northern Watch
Good evening Alan
A slight amendment needed I believe to the db.
TOM898 showing EGPG - LTAI, should be EGPF - LTAI.
Best regards
Keith
Thanks for that Keith, consider it done
AoD
GMI6311    LTAS - EDDL
GMI4906    EDLW - LTAC
3FF419  DMERE             2015/08/01 12:33:19
CYYZGUY
40" LED Monitor
40" LED Monitor
X
#1904
A44E07  N377CJ B737 BBJ                                                        2015/08/01 19:42:25
Yesterdays Gambian unknown is not spurious after all as Ariana have a new A320 about as 09A039 possibly C5-AAH.
X
